More interior updates and fixes
iamthewreckingcrew
Post by iamthewreckingcrew »
Well, this morning I went back out to the garage to see what else I could fix on my 68.
When I bought it almost ten years ago, there were no keys for it. The old guy couldn't find them. I replaced the ignition switch back then so I could at least start it with a key.
This morning, I went back to see what I could scavenge off of the 81. I took the door lock out of the 81 and swapped it for the one in my 68 driver's door. Another easy job. The locks were identical except for the part that actually hooks to the linkage. They are held on by a clip and I took a pair of needle nose and switched the parts. PERFECT. Now I can actually lock my 68. I'm going to swap the other one out later.
I also swapped the window cranks. My 68 didn't have knobs on the cranks when I got it. They worked great too.
I'm getting excited about working on my baby again.
68 F-100 Short Box 2wd
302/c4/3.50
81 F-100 Long Box 2wd
460/c6/3.00
92 F-150 Lariat 4wd
302/auto couldn't go wrong for $500
rjewkes
Post by rjewkes »
Sweet, Good luck :thup:
BiggDogg
Post by BiggDogg »
Hey that's great. So the window cranks from the 81 fit ok in the 68?
1970 F250 Camper Special
yes almost all ford window cranks will fit. it just depends on what you want them to look like plastic or the metal ones that came from the factory.
BiggDogg
re: More interior updates and fixes
Post by BiggDogg »
ah, good to know, thanks... probably explains why I have two different ones :lol: Now I can go junkyardin' and get a matching pair!
the closest match are the ones from the 73-79 trucks.
iamthewreckingcrew
They matched good enough for me. The design is the same, but the 81 handles had a slight angle built into them that makes them come out from the door panel slightly instead of being almost flat against the door panel like the originals.
302/c4/3.50
460/c6/3.00
92 F-150 Lariat 4wd
BiggDogg
Post by BiggDogg »
Thanks for the info. The two that I have right now are mis-matched, one is cracked, and one is wobbly, so just about anything will be an upgrade :lol:
ford4x4fun
Post by ford4x4fun »
Makes you wonder what else is just an easy swap like that...
CNR Radio Instructor
US ARMY Retired
1971 Ford F100 4x4 (390)
2015 Ford F250 Crew Cab 6.7l
iamthewreckingcrew
I sure wish I could make the power steering and tilt wheel from the 81 work in my 68. I'm not tossing it until I'm SURE I can't though.
302/c4/3.50
460/c6/3.00
92 F-150 Lariat 4wd
