Quick question....
03svtsnakevert
Quick question....
Post by 03svtsnakevert »
Ok, I posted something about my dash lights in the interior section...well after replacing the light switch and removing the cluster and cleaning all the contacts, they work...here is the question:
I have the cluster for the idiot lights and when I turn the key on the "ALT" light comes on but not the "OIL" light, is this correct? This is on a 72.
Thanks again!
wt4speed#2
Post by wt4speed#2 »
IMO I think they should both come on as the self chck. try removing the lead to the oil sending unit and ground it see if the "oil" light comes on if so maybe a bad oil sending unit. If it does'nt come on the oil bulb may be bad I maybe incorrect but it's a starting point.
Tony B.Image
DFW Area
"Someday...
I hope you to get the chance,
to live like you are dying"
Member#'s 236 & 403
Úlf the Comedy Sidekick
wt's ride
thebucket
03svtsnakevert
wt4speed#2 wrote:IMO I think they should both come on as the self chck. try removing the lead to the oil sending unit and ground it see if the "oil" light comes on if so maybe a bad oil sending unit. If it does'nt come on the oil bulb may be bad I maybe incorrect but it's a starting point.
I know that the bulb is good, however there is no engine in the truck right now...this is probably why the light does not come on
wt4speed#2
Well some how I missed that part find your oil sending unit wire and ground it see if your light comes on .
Tony B.Image
DFW Area
"Someday...
Member#'s 236 & 403
wt's ride
thebucket
seattle67
re: Quick question....
Post by seattle67 »
Yup, WT is correct, try grounding the wire with the key on and it should light up. Basically the oil light sender can be thought of as a light switch, thats all it is. No engine = no sender = no light switch. If the wire is not connected to the light switch, then there isn't anything to turn the light on. The sender is switching ground, so if you ground the wire that goes to the sender, on goes the light.
03svtsnakevert
that is what it was...grounded the lug and hit the key...presto! oil indicator light...can't wait to get the motor in this truck!!
