Fuel Gauge Question
smclaren
re: Fuel Gauge Question
Post by smclaren »
Ahhh ... thanks Steve. Flasher unit, eh?
Yes, mine is currently swinging in the breeze below the dash (the flasher unit that is :D )
Image Steve - Caloundra, QLD, Australia Image
1969 F100 4x2, RHD, Base Model, 240ci, 4sp, Dealer Canopy, No Bloody Radio.
SteveC
Post by SteveC »
now there are some trucks that have two...mine does..one for emergency flasher and one for the turn signals that is attached to the back of the instrument panel...
glad i could help
1967 f-100 4x4
1988 ford f150 xlt lariat
1961 VW Beetle (wifes car)
Thunderfoot
Re: re: Fuel Gauge Question
Post by Thunderfoot »
smclaren wrote:
Thunderfoot wrote:Not sure why it has the brown stuff on it unless it was put on to keep it from moving from vibration...
Didn't work then, did it ? :wink:
:lol: .... Nooo, they wear out over time and need tweaked back in if they can... They way they work is they send out a pulse instead of a constant voltage... The way they make this pulse is by using a bi-metal strip in them that heats up and cools down to make a contact. As it heats up it will bend away from making a contact (connection) and then it will cool down and bend back to make contact again... that adjustment changes the tension on the bi-metal strip as to how hot it has to get to bend away from the contact...
So as they get used and old the tension (strength) of the bi-metal strip weakens...
Hope that wasn't to confusing it is a little hard to explain but thought I would try. :roll:
FYI this is also how a flasher for the signals works as well...
like Steve said... That other round thing with the 2 prongs above it is the flasher for the turn signals. :thup:
smclaren
Post by smclaren »
Great explaination Thunder.
Looks like you and SteveC have helped not only me, but a stack of other guys.
May be worth expanding the "fuel gauge technical tips" on the main site to include this issue, as it sounds really common.
Thanks again.
ford4x4fun
Post by ford4x4fun »
Good Info you learn something new every day!
CNR Radio Instructor
US ARMY Retired
1971 Ford F100 4x4 (390)
2015 Ford F250 Crew Cab 6.7l
smclaren
Post by smclaren »
Hi SteveC and Thunderfoot
I just placed a HUGE order from NPD for a heap of 'stuff', included is a new IRVR #10804-2
I'll let you know how it goes.
rjewkes
Post by rjewkes »
wondering now Steve, if the bloomin' orange markers are something a previous owner mounted in to get the turns working?
smclaren
Post by smclaren »
Hi rjewkes
I don't think so ? There is a requirement in Australia for vehicles to have Brake, Parking and Reverse lights (all served by the standard F100 tail lights - note our small insert lens in the tail light is white for reverse lights, where yours are amber/orange/yellow for turning lights), which meant a seperate turning light is needed and was installed by the factory.
Intersting though, I don't have hazzards !!!
rjewkes
Post by rjewkes »
all my lenses also have the clear square for backup.
they don't look bad your orange ones.
