turn signal problem
ciscom1986
turn signal problem
Post by ciscom1986 »
got a 68 f100, the signal doesnt do anything both flashers are getting power, brake lights work. doesnt power at all any ideas? :?
thanks for the help!
Thunderfoot
re: turn signal problem
Post by Thunderfoot »
Did you try a new Flasher? After that check the "Blue" wire on the connector at the base of the steering column for the Turn Signal Switch (TSS). make sure you have power going up the column, if you do then the contacts on the TSS are bad. You may just be able to put a new cam on it or will have to replace the TSS itself.
old_mare
Post by old_mare »
I know its obvious and redundant, but make sure all bulbs are good.
I used to have a similar problem where the RR turn signal would light solid and nothing in the front, turned out to be a wiring problem between the TSS (turn signal switch) and the dash. There may be an issue in your TSS, thats pretty common to my understanding.
I'm sure there are others on here that can answer better but I just thought I'd cover first base ;)
Good luck,
-JT-
"I'm a man, and I can change, if I have to, I guess." -Red Green
I'd rather push a Ford than drive a Chevy!
1930 Tudor : 1930 Pickup : 1969 F250 Custom
Underdog97
Post by Underdog97 »
Are the indicator lights on and no flashing or is there just nothing happening at all? PM me if you need a switch as I have used ones in tested working order.
ciscom1986
yeah! nothing is happening at all! i have one new flasher the other one ill change today but power is going through both of them.
rjewkes
Post by rjewkes »
oddly with bad ground the brakes will work ok but the turns will not. but then they would atleast light.
