Water Level Theory for Whiskey Bottle In Cab Fuel Gauge!
ford4x4fun
Post by ford4x4fun »
I know this isn't the safest thing to do, and the cops probably wouldn't like to see it either, But I was thinking about taking an antique bottle and using it as a water level, that corrisponds with my fuel tank. Basically it would be a direct reading of how much fuel I have. Wanted to know what everyones thoughts are on this. The link I am providing is actual water level, a little more than what I would need.
http://www.factsfacts.com/MyHomeRepair/WaterLevel.htm
Basically I would need a flued line, and an air line running back to the tank, and than mount the bottle to the dash. Sor of a Rat Rod, kinda thing, but I have nothing but time to sit here and ponder ideas. So What do you all think!!!
CNR Radio Instructor
US ARMY Retired
1971 Ford F100 4x4 (390)
2015 Ford F250 Crew Cab 6.7l
seattle67
re: Water Level Theory for Whiskey Bottle In Cab Fuel Gauge!
Post by seattle67 »
Well sure, it would work to a certain extent, and look really cool. But if you got in a crash it would turn you into a blow torch.
I really hate being negative to such a cool idea, but I just cant picture a way to make it safe.
Don't give up on it though, this requires a brain storm!
ford4x4fun
I was thinking maybe a plastic whiskey bottle, good stell tubing, and than this set up just outside the fuel tank. I think I could wire it so that if I lost power for any reason it would shut off...
http://www.rvpartscenter.com/ProductDet ... 454&SID=32
This isn't quite the right thing I just haven't found the right one yet... Still looking!!!
I have been sitting here brain storming!
US ARMY Retired
ford4x4fun
Ok I found the right thing to shut the fuel off...
http://psa.manufacturer.globalsources.c ... -Valve.htm
Now I just need to find a way to keep the bottle from coming apart in a wreck... Don't know if that is 100% Possible, but maybe a way to make it safer!
US ARMY Retired
ToughOldFord
Post by ToughOldFord »
That's too dangerous. Remember, gas isn't just flammable, it's an explosive. Even just the small amount in the bottle will send enough shrapnel in your eyes in a crash to blind you for life even if you survive.
If your gauge doesn't work just get a long stick.
ford4x4fun
I actually saw this on a TV show (Hot Rods or Something) a while back... I know it is possible, and I know it isn't the safest thing in the world, but then the fuel tank is right behind the seat anyhow. This is just an idea, and maybe just something I will implement to work while it is sitting there, or I might not put it in at all. I was thinking I might be able to do it with a float in the tank as well. So what was in the bottle was actually just water or something. I believe that would be possible as well. I will have to look more into it, and if anyone has some more ideas that would be awsome as well.
US ARMY Retired
it is a neat idea. i would put it low under the igntion switch or something like that. i am seeing a little glass vial for this use. a whiskey bottle would be to large. even a pocket sized bottle would be too big.
ford4x4fun
So I get to computer with civilian internet and found out that there was no picture at that link... What a bummer...
:thup:
US ARMY Retired
