how to install philco am radio ???
LUVMY69FORD250RANGER
Post by LUVMY69FORD250RANGER »
i found one but took me like half hour and ending up bending out the mount in the one i found it in, MAN what a workout. do i go through the glove box?? hoping someone put one in before. this is original am radio .
THANKS
Joe Kriston
re: how to install philco am radio ???
Post by Joe Kriston »
Pull the glove box out and reach around and loosen the nut holding the back side of the radio onto the bracket...Although I haven' figured out how to do it w/o scratching the pushbuttons a little bit...
ford4x4fun
Post by ford4x4fun »
Yep Joe is on it,
Remove the glove box, it is real tight in there. The truck I did it in, the Defrost tubing was even out of the way and it was still a little difficult to get right!
CNR Radio Instructor
US ARMY Retired
1971 Ford F100 4x4 (390)
2015 Ford F250 Crew Cab 6.7l
Underdog97
Post by Underdog97 »
I've found it makes the job easier if you also take out the ashtray assembly to get at both the speaker and the radio. The paper glove boxes come out easier with the glove box door removed as well.
Underdog97
Also being a 69 I'd be really carfeful when removing the emergency flasher switch from the paper glove box and the connector for it too as they have a tendency to come apart really easy from the back where they're crimped together.
Joe Kriston
PPs. ...Make darn sure you have a good speaker in there...That was the reason I took my radio out in the first place...And make sure that little 2 amp fuse doesn't fall out of the socket when you're re-connecting it, like it did with some idiot I know :oops:...
kilog55
Post by kilog55 »
where would you get a replacement speaker that would be correct as far as ohm and power
peanutman
Post by peanutman »
Jc whitney, lmc npd, has nos speakers for our bumps.
sideoilerfe
Post by sideoilerfe »
peanutman wrote:Jc whitney, lmc npd, has nos speakers for our bumps.
But I don't think they're the same. I mean, the bracket that holds the speaker in the dash attaches to the magnet of the speaker. The newer speakers have larger magnets and don't always fit into the radio dash opening.
You could get the old one re-coned.
1970 F250 4x4 390/4spd
1968 F250 4X2 360/C6/No Rust!
