Horn
Horn
I have a 70' F100 Sport and Ranch Custom, 360 3MT, everything works but the horn - replaced horn, relay, switch, pad - wiring seems ok (ground is good). Drives me nuts!
1970 F100 Sport Custom Farm & Ranch Special, 360, 3sp, bone stock!
re: Horn
Did you check to make sure the spring-loaded contact is there and intact?
It gets mounted into hole number 2 in this picture:
- Mohillbilly
- Mohillbilly
- 71 LONG BED
re: Horn
I pinched my horn wire trying to put my radiator back in and it made the horn blow! Scared the bejesus out of me!!! It was one of those small after market air horns.
The wire cover melted a little but it still works, One day I'll patch in a new wire.
John Member #1549
- Fake Name
Re: re: Horn
That part has an official name:FORDification wrote:Did you check to make sure the spring-loaded contact is there and intact?
I
"Horn Carbon"
one of my first lessons as a jobber parts guy, long ago. Along with how to use the those big, long binders of parts catalogs. It just ain't the same with these computer dealies today. Nope. It's much better!
fn
- 68F250
re: Horn
That's one circuit I've never checked out, the horn button.
Basically it's hot all the time, looking for a ground. After going thru the button, how does it get back to ground? Does it have to go thru the bearings in the column to reach the chassis? The rag joint isolates the shaft to the steering box.
Barry
- seattle67
re: Horn
Mike,
You may see + 12vdc there, but only if the horn relay is plugged in and the the coil in it is good. In that situation, you would be seeing the +12vdc that is going through your horn relay coil. (This would be a good thing as it means your coil is good)
What confuses some people with the horn circuit is that the +12vdc goes straight to the relay, its not switched, it's the neg 12vdc that's switched. What happens when you push on your horn button is that it contacts ground, this ground is picked up by the horn carbon and sends the ground, or - 12vdc to the horn relay. The relay is now energized, closing a contact that sends +12vdc to your horns.
I hope that makes some sense.
