98/01 dodge 40/20/40 seats will the brackets work in my 71 f100 or are thes modified
http://www.fordification.com/images/FAQ ... ats_07.JPG
DODGE 40/20/40 SEATS 98/01
re: DODGE 40/20/40 SEATS 98/01
Was thinking same thing because they already have shoulder belts built into the seat and I noticed they appear fairly "routine" on bottom end, checked out a buddies at work.
Other question is will it fit and still have the gas tank behind the seat or does gas tank have to go to get it to fit? Also, what is the Dodge version that might come in leather (like Eddie Bauer)?? Sorry to hijack, but was just about to post same question.
Banjo.
Banjo.
If its already in a truck like yours and your just buying from another bump owner, it should fit fine in your truck because the seller would of already done modifications to make it fit. Like Banjo said, check to see if the seller has the in-cab gas tank...
... if its just a pic you found & like, and you're thinking of purchasing a dodge seat elsewhere, you will have to do some modification to get the seat to bolt up to your truck, but other than that, it looks like it would be a nice addition. Good luck!
1970 F250 Camper Special
- 69F110
That looks like some of the pictures that where put up to show different seats in our trucks. Thanks makes me want to go find me a new seat.
1968 Ford Ranger Lb
2007 Harley Electra Glide Classic
no it is not my truck i did get the pics off this sit
So are you gonna try to get one and install it? Keep us updated with photos if possible ![Thumbs up :thup:](./images/smilies/icon_thumright.gif)
