small updates
- customcrewcab
small updates
got the t-56 transmission in. had to relocate the trans crossmember back alot. also got the brakes plumb with 3/16 stainless with framethrow stainless tabs. also started to wire it but trying to get the hyrdoboost lines installed first.
- flatblack
re: small updates
wow that is an insane setup you got there....
- rjewkes
is the backwards exhuast for clearance on the hydroboost or for a turbo? or both?
lookin' good.
lookin' good.
- customcrewcab
re: small updates
its so it can be ran into the turbo. plenty of room for the hyrdoboost. heres a pic that shows it . turbo on the driver side to it can go into the inner cooler then into the throttle body.
- rjewkes
cool. can't wait fr a video with it running and eating some chevies and shitting out dodges.
- MaxKlinger
re: small updates
T-56 as in the Tremec box used in the Camaros, Firebirds, Corvettes, and Caddy CTS-V? Nice work! I didn't know you could mate them to Ford motors, did you have to make an adapter?
Tony
'72 F100 LWB 2WD Custom, 360FE, T18
'05 Focus ZX4 ST - 2.3L, 5spd
'83 F150 LWB 2WD, 300-I6, C6 scrapped 2006
- customcrewcab
re: small updates
they put them in newer mustangs and they sell they them at bolt up to a 302/351 and even 460. this on i got from d&d performance and it a new viper with a bellhousing they make and it have a acouple other machined parts. you can see the viper snake on the side by the shifter. it rate for over 600hp and it cost about a grand more then the regular one. i just designed with shifter for it in autocad. hope to have it cut out in the next couple weeks.
