Tis true. Found a vac leak cuase the carb was a little loose. It was driving fine but today it just started idling rough. when i tightened the carb down on the nuts for the carb to spacer/masnifold studs it acted a little better.
then i found a loose wire on the cap #5 to be exact.
pushed it back down on the cap.
the other day it did act like it only had enough volts for half a crank. but waiting 20 minutes and it fired right up without any problems.
it was surging on the way home tonight, and idling real low in gear, after i fixed the problems above it now idles rough but does stay running. but the lights on the cab flicker real bad. the rest of the lights seem ok but i do have that relay in.
i'm gonna replace the belts tommorrow cuase i needs them, if that doesn't help what next? could it be just the volt reg? if so i'll go ahead and upgrade to my 100 amp alternator/regulator and harness. can the amp guage/shunt handle the extra amps/volts?
there be gremlins in me engine compartment. Fixed TY
- rjewkes
- SteveC
re: there be gremlins in me engine compartment.
i know how those days go.
Seems like every thing goes nuts at once![Laughing :lol:](./images/smilies/icon_laughing01.gif)
1967 f-100 4x4
1988 ford f150 xlt lariat
1961 VW Beetle (wifes car)
1967 f-100 4x4
- Wes
The ammeter should handle the big alt just fine. The way the stock ammeter is wired it shows you the current draw you are using. So unless you have a bunch of KC daylighters wired in down stream of the ammeter.
Wes
67 F250 High boy
69 Bronco
If you can't see fit to stand behind Our Troops...Please stand in front of them![Smile :)](./images/smilies/icon_smile.gif)
67 F250 High boy
69 Bronco
- rjewkes
ok cool. also found the coil to distributor cap wire(high tension lead?) was arching along itself even without anything near it. Changed it out for a spare and that took some of the roughness out of the idle.
Well The altm battery and voltreg check out.
Noticed a real bad bogg down when accelerating on the way to the parts house.
Got a rebuild kit for the carb and some carb cleaner. came out fired it up and the rough idle was gone.![Hmmm :hmm:](./images/smilies/icon_hm.gif)
hope this ain't one of those come and go problems. Could it have been just Bad Gas from Murphy usa/Wal*Mart?
