quick question about a block heater
BRUTUS_T_HOG
Post by BRUTUS_T_HOG »
are the plug ins universal? mine is rotted away
ASE Certified Technician
Thunderfoot
Re: quick question about a block heater
Post by Thunderfoot »
You're talking about the 110v plug correct? Yes, it is just a plug... should be a standard 3 prong plug in.
If you replace a section of the cable be sure to use the same wire gauge as it has now.
mk
Post by mk »
If you're talking about the heater end, they are universal as well. The cords are available with a straight or a 90 degree end.
mike
~Will Rogers
Mercury truck ID thread:
Ford truck model history:
Using dentside fender liners:
Matchbox diecast bumps:
