Installed new door weatherstrip. Now door is hard to shut.
theogre5150
Post by theogre5150 »
I just installed some new weatherstrip for my doors. I have not got all of it on yet but I noticed that it is now hard to close my door all of the way. Also, when I go to open the door, it acts like it is SUPER spring loaded and pops open. My question is, is there an adjustment somewhere on the door to allow for the new weatherstrip?
Ranchero50
Re: Installed new door weatherstrip. Now door is hard to shut.
Post by Ranchero50 »
Probably not if the outside front and rear edges line up with the cab. May just take a while for the seals to relax.
Jamie
flyboy2610
Post by flyboy2610 »
This is normal for new weatherstripping. It will take a little time for the new rubber to 'settle in.'
70shortwide
Post by 70shortwide »
a buddy of mine just did this, 3 times! he kept ordering different kits because they didnt fit right, like your experiencing. he finally got the right ones and they fit perfect. he was ordering the right ones for his truck, apparently there are a few suppliers that sell the wrong ones. i will call him later and find out which ones he got. he had to call a bunch of different people to find out what was going on. he was pissed when he couldnt return the others once he found this out! :x
67fordkc
Post by 67fordkc »
I would be interested in his answer also, since i have the same problem with the news ones I installed a month ago. They have relaxed some but are really tight.
mrtleavitt
Post by mrtleavitt »
I've replaced weather stripping on 2 old fords, one set from LMC and the other from JC Whitney. They both were hard to shut for a few months but eventually worked out just fine. I liked the JC Whitney ones better. What I did was adjusted the door stricker out just a hair so there was still pressure on them but the doors would close good, and then every week or so adjust the striker back in little by little until the body lined up again.
theogre5150
Thanks for all of the responses on this. I figured that over time that the door would compress the seals. I hope.
rjewkes
Post by rjewkes »
i heard that with all new seals if you leave the window up the doors won't close right unless you roll the window down a hair. until the seal breaks in.
proably different cuase than your problem?
rjewkes wrote:i heard that with all new seals if you leave the window up the doors won't close right unless you roll the window down a hair. until the seal breaks in...
That's only with vehicle doors without a full window frame. That's not an issue with these trucks, since the glass weatherstripping have nothing to do with the door closing.
70shortwide
sorry guys, ive been busy. i called my friend, he couldnt remember. hes gonna look at his receipts tonight. he said the lmc ones were ones that did not fit right.
theogre5150
I adjusted the striker bolt. As of today, they still have not compressed.
jzjames
Post by jzjames »
So which brand did YOU install?
saidyene
Post by saidyene »
You should pick up the new Hot Rod mag. The one that has 101 tips in it. I borrowed it from a friend today and it has a solution for this problem in it. I don't remember the details or have the mag with me so I wont give you bad info.
theogre5150
I bought the ones from Blue Oval.
71 LONG BED
Post by 71 LONG BED »
Don't forget, your compairing almost 40 year old weather stripping to brand new. Mine is still a little tight after almost 2 years, but its a nice air tight seal. I like the nice tight feel. :2cents:
John Member #1549
Image Image Image
