Tail Lights Still Staying On
FordTruck
Post by FordTruck »
My tail lights wouldn't go off. The second I plug in the plug under the hood the lights come on and wouldn't go off. All the wires behind the light sockets are all hooked up but could it be my light switch or what? I just got my truck drivable and need lights so people wouldn't hit me :lol:
60 Mercury Comet
65 Ford Econoline
77 Ford F250 "lowboy" 4x4
09 Harley Xl1200c
Joshpow
Re: Tail Lights Staying On
Post by Joshpow »
Have you checked the brake light switch? It may be worn out and not turning off. If that isn't it, I'd say you got a short.
Josh
72 F-100 Ranger XLT SWB
71 F-100 Custom SWB
67 F-350 Dually Dump
02 F-250 Stroke
FordTruck
Post by FordTruck »
I've unplugged the brake light switch and still nothing where do you think the short could be?
60 Mercury Comet
65 Ford Econoline
09 Harley Xl1200c
bluef250
Post by bluef250 »
Check the ground at the tail light on both sides. Then check the bulbs, clean the contacts and use some dielectric grease putting the assemblies back together. You may want to get some different tail light bulbs and try them also. Let us know what happens.
You've unplugged the brake light switch and the lights stay on? Sounds like a previous owner has done some wire hacking. :roll: One common problem area is previous owners who didn't know what they were doing modifying the wiring back by the taillights trying to install a trailer connector. How does that wiring look? Has it been tampered with?
And let's clarify: Is it the brakelights or the taillights that are staying on?
FordTruck
Post by FordTruck »
I couldn't find any hack wiring under the dash and under the bed looks fine. I think it may have someting to do with the light switch because the front lights will also do the same if I put bulbs in them. I checked the gronds behind the tail lights and they're fine. From what my mom says nothing changes when the brake pedal is pushed.
60 Mercury Comet
65 Ford Econoline
09 Harley Xl1200c
FordTruck
Post by FordTruck »
Ok today I went through and took every fuse out one by one and the tail lights didn't go off. I'm gonna be putting a 67 bed on it but I think I'm gonna have to use the 70's bed wiring. So I want to figure it out before I put another bed on. So anyone have any ideas on the problem?
60 Mercury Comet
65 Ford Econoline
09 Harley Xl1200c
Re: Tail Lights Still Staying On
dont the brake lights go through the turn signal switch in the column? that could be were the problem is. or at the bottom of the column.where the wires come out .
Thunderfoot
Post by Thunderfoot »
Try unplugging the light switch, the marker/tail lights are not fused so pulling the fuses wont turn them off. If you they go out after unplugging the light switch then either the switch is bad or some wires there are shorted or miswired. :2cents:
FordTruck
Post by FordTruck »
Thunderfoot wrote:Try unplugging the light switch, the marker/tail lights are not fused so pulling the fuses wont turn them off. If you they go out after unplugging the light switch then either the switch is bad or some wires there are shorted or miswired. :2cents:
I tryed unplugging the light switch too and they where still on.
60 Mercury Comet
65 Ford Econoline
09 Harley Xl1200c
hook everything up turn the truck on. disconnect the turn signal wiring at the bottom of the column. dont cut the plug off.
FordTruck
Post by FordTruck »
fordman wrote:hook everything up turn the truck on. disconnect the turn signal wiring at the bottom of the column. dont cut the plug off.
Didn't do it still on.
60 Mercury Comet
65 Ford Econoline
09 Harley Xl1200c
you have some wires crossed someplace. you are going to have to just trace them down. the only other thing i can think of is the front turn signal bulbs sockets. one of the bulbs might be crossing and touching both terminals and feeding back some how. i do remember someone having that problem. they replaced the bulb and thier problem went away.
FordTruck
Post by FordTruck »
Me and my dad did some tracing and its btween the plug that comes through the fire wall and my fuse block. So I guess I know what I'll be doing tommrrow :roll:
60 Mercury Comet
65 Ford Econoline
09 Harley Xl1200c
check the back of the fuse box. maybe something has broken off and is feeding back through the brake lights.
