Instrument cluster removal help
papabug71
Post by papabug71 »
Anyone got any tips for removing the cluster from our trucks? Mine is looking worn & im ordering a new one from DC. I can remember when we restored this truck, I was in the 6th grade & I could pretty much shimmy under the dash on my back. Unfortunately, I have since put on a little weight & can only get 1/2 way in on my back.
I guess my question is: If I unhook the speedo cable, will the wiring harness have enough slack so I can pull the cluster out of the dash a bit & remove the plug? Or is it so tight that im going to have to enlist the help of my 3 yr old to reach up & unplug it from behind?
I plan on giving the entire cluster/ gauges a makeover while im at it so any help on this subject is greatly appreciated!! :fr:
Matt
Mine since 5/7/'94
302 / 3 speed / 3:25's
mljjones67
Re: Instrument cluster removal help
Post by mljjones67 »
Yes there is enough slack to pull the cluster out and unhook the speedo and plug.
papabug71
Post by papabug71 »
Excellent. Thanks for the reply!
Matt
Mine since 5/7/'94
seattle67
Post by seattle67 »
Mike is right, he usually is :thup:
I just wanted to add that personally I have always found it much easier to pull out if I reach up and disconnect the speedometer cable first.
i usually push the cable through the firewall first and then pull the whole cluster. it makes it easier on me to reach the cable. that last post had a joke in it. if you read it to fast.
papabug71
Post by papabug71 »
Nice one fordman!lol! :lol: Took me a couple of trys.
I'll try to unhook the speedo first if I can get my hands behind it.
The speedo cable just "pops" on/off right?
Matt
Mine since 5/7/'94
wt4speed#2
Post by wt4speed#2 »
Nope mine is lefty losey ,righty tighty
Tony B.Image
DFW Area
"Someday...
I hope you to get the chance,
to live like you are dying"
Member#'s 236 & 403
Úlf the Comedy Sidekick
wt's ride
thebucket
papabug71
Post by papabug71 »
Cool beans! Thanks for the help guys! :fr:
Matt
Mine since 5/7/'94
seattle67
Post by seattle67 »
fordman wrote: that last post had a joke in it. if you read it to fast.
You're a sick man Craig. :lol:
dcbullet
Post by dcbullet »
A tip is to loosen your steering column and drop it down 3/4 of an inch. This way you have more room to pull the cluster out and less of a chance to scratch the top of the steering column.
