i have a 67 f100 i need to know if a wiring harness out of a 72 f100 will switch out anyting at all would be helpfull the more details the better thanks
adam
wiring trouble
wiring trouble
67 f-100 custom my grandad and my dad owned the truck before me so its a family thing one day my son will have it
- Hawkrod
Re: wiring trouble
67 wiring is very different than 72. You could switch it but you would need to change everything like the instruments, ignition switch, turn signal switch etc... There were a lot of changes. It would be easier to just find a 67 harness. Thay are common enough but it is a one year only item. I may have a complete cab harness if you really need one. Hawkrod
39 Ford Dlx Cpe
59 Tbird 430
60 Lincoln
(2)62 Tbirds
(3)68 Cougar XR7-G's
69 Cougar 428CJ 4 speed
77 1/2 F250 4X4
86 SVO
76 F250 Crew Cab
67 F250 Ranger
59 Tbird 430
60 Lincoln
(2)62 Tbirds
77 1/2 F250 4X4
86 SVO
76 F250 Crew Cab
67 F250 Ranger
Re: wiring trouble
The 67 wire harness is not interchangeable with the other years of the trucks... 67 is kind of a one year off of the bumps in a lot of ways...
There are lots of differences on the harness to a 72; ignition switch, instrument cluster, and turn signal switch are just a couple...(like Hawkrod said)
If you’re looking for a replacement harness check the parts for sale section, ezernut9mm had one for sale there a while back might check it out.
http://www.fordification.com/forum/view ... a&start=45
Re: wiring trouble
i was able to swap one from a 69 but the only thing i had to change was the ignition switch. and i had no way to get power to the heater fan cable switch. i finally found a 67 harness. and i am going to swap it back as soon as i get a chance.
Re: wiring trouble
ok thanks for the info im just gonna try and get a 67
- Dragon
Re: wiring trouble
Yes they are go look at a 66 though/ I pulled my 62-1/2 F100 harness for a 67 F100 ad it was real close except no rubber boots. Wiring code was the same.Thunderfoot wrote:The 67 wire harness is not interchangeable with the other years of the trucks... 67 is kind of a one year off of the bumps in a lot of ways...
Old Fords Rule
Was a Ford Service Tech
98 Volvo S70 2.4T Auto
My Gallery
Spark test
My Gallery
Spark test
Re: wiring trouble
i think shanye was refering t o the 67-72 harnesses only. since the poster had asked about using a 72 harness. so maybe a 66 harness would work also. thats good to hear.
Re: wiring trouble
was only referring to the Bump side trucks... I haven't worked on a Slick side yet... although I will be helping my best friend with a 66 he got to fix up for one of his daughters... I'll check it out this spring when we get rolling on it, and this is some good info to know.fordman wrote:i think shanye was refering t o the 67-72 harnesses only. since the poster had asked about using a 72 harness. so maybe a 66 harness would work also. thats good to hear.
