what is a factory highboy???
truckfreak
Post by truckfreak »
i have heard that a "factory highboy" has a 4" lift stock i dont know if it ment leaf springs or what,
and from another source i heard that 72-77 f250s had high arch leaf springs naming it the highboy,
and i have heard that a f250 4x4 was just taller than a 2wd so it was nicknamed a highboy....so what is it...what exactly is a factory highboy?
bumt72
re: highboy
Post by bumt72 »
LOL, I have had the same question but have been too embarassed to ask.
Kep
1972 F250 Da Big Ugly Man TruckDa BUMT
1961 F100 Stepside (Father/Daughter Project)UnNamed
truckfreak
re: highboy
why?! its all about learning man. trust that i can and have done a hell of alot of wrenching, rebuilt trannies, engines, brakes, you name it...its just sometimes theres things that slip by. i have just heard so much conflicting information about it that im trying to get it straight. another head or nine can never hurt.
heep70
re: highboy
Post by heep70 »
:hmm: :dk:
Greg
2000 Subaru Outback limited.
2013 Polaris Pro 800 RMK 163"
My last 1971 "Highboy" pics
cobraF100
re: highboy
Post by cobraF100 »
I looked through some of my Books and could find nothing about it being a fatory 4" lift...I wonder why... :hmm:
So I just learned it from Ya'll,about it being a Factory Install...
Chris
Never Forget Our Soldiers
truckfreak
re: highboy
okay i still dont know, i wasnt trying to educate anyone here, just trying to get some more ideas. i dont know if you were just being sarcastic here cobra or what :eek:, but im still clueless to what exactly factory highboy means. any more ideas out there it would be much appriciated. but someone with a straight answer would be better.
cobraF100
re: highboy
Post by cobraF100 »
O...Sorry Dude I wasn't trying to be a Smart A$$......
I miss read it and thought someone said it "was a Factory install"
But I still cant find it in any of the Ford Truck Books I have here :hmm: We'll have to wait till Keith see's this Post,Hopefuly he will know...
Chris
truckfreak
re: highboy
its ok cobra, the 4 inch factory lift thing is just something i heard from someone. it wasnt ment to be passed as a fact.
willowbilly3
re: what is a factory highboy???
Post by willowbilly3 »
Technically I consider any divorved T-case, low pinion front axle, F-250 a high boy so that would go back to 59. Normally we don't see the term used much on trucks older than 67. I am not sure of the exact height of the rear spring spacer but it is probably around 4 inches, this would be the "factory" lift i suppose.
The trucks made from mid 77-79 were about an inch lower and while some of those owners tout them as highboys, the purists consider the last low pinion/divorced T-case trucks to be the end of the highboys. That would make mid 77 the cut off.
The term does get loosely thrown around and even F-150 owners with a lift kit like to jump on the highboy bandwagon, they really aren't
Rockcrusher
Post by Rockcrusher »
I posted this reply in the 4X4 section . . . I didn't know you posted the same question here.
The highboys generally had a 2-2½+" lift block between the axle and spring packs. I believe the first highboys hit the street in the '63 model year on both the LWB F-100 and F-250 4X4's. After the F100's went to front coils only F-250's got the blocks.
Once upon a time, I owned a pair of LWB 4X4 trucks . . . an F-100 and an F-250 from 1963-64. Both had the lift blocks and the bumper height of both was at least 24-26". Most other Ford 4X4's of that time were a straight SOA without the blocks. Incidentally, both trucks used the same frame . . . The major differences were the transfercase and rear axle.
Rockcrusher
http://www.rockcrusher4x4.com
Ignorance is sticking your hand in the fire 'cause you don't know what it is ... Stupidity is doing it a second time.
2mny4rds2list
Post by 2mny4rds2list »
I have been told by a friend who is very knowlegeable about fords & was a ford mechanic from 1965 - 1985. He said that "Ford" never labeled or named them High Boys. He says the "term" High Boy was just a knick name adopted by the general public to the early F-250 & F-350 4x4s. It was because the F-250 4x4 & F-350 4x4 had a tall stance compared to their 1/2 ton conterparts. I take what he says as a very good source as he has his own garrage & rebuilds old fords for a living. There is always some old rare ford in there that someone is trusting him put put it back just as it left the factory.
Hope this helps!!
1972 Ranger F-250 4x4 High-Boy & 1965 Ford Galaxie 500 LTD 2 door fastback & 1974 Ford Galaxie 500
willowbilly3
Right you are, except the 66 and older F-100 4x4s were tall too, though some debate as to whether they should be considered in the highboy genre or not.
2mny4rds2list
I don't know how high the 1/2 tons you are refering to stand but my 1972 F-250 4x4 "High-Boy" Stands at 6ft 9in from ground to top of cab with new stock springs (no lift) with 33-12.50 tires. Just thought I'd throw that info out here for people use if they want. My truck is a camper special so maybe that makes it a little taller??
willowbilly3
The heavier duty GVw F-250s do tend to be taller, at least in the rear. The base GVW is around 6400 and those 4x4s almost sag a little in the back. By the time you get up around 7500-8800 they are setting up in the back end and pretty stiff.
my367s
Post by my367s »
I have a 64 f100 4x4 and it has a 4 inch block between the rear axle and the springs,which makes it about 26 inches off the ground and as far as I know its stock.I have been told that the 1/2 ton 4x4s and the 3/4 ton 4x4s had the same frame,the difference was in the axles only.Jerry
Gerald Cook
1967 mercury ranger 1/2 ton-work in progress
1967 mercury 1/2 ton
1967 ford 1/2 ton-daily driver
1964 ford 1/2 ton 4x4-next project
2001 ford f150 4x4
