427blackpearl wrote:mike did you use a diffrent lug pattern? i kinda like the c-57's in gun metal but there only in 5'' lug pattern
also hows your truck workin out? any new pix?
Yes I did. As you all have discussed, there is a pretty limited selection of wheels made for the 5x5.5 bolt pattern, & then when you finally find a wheel that'll bolt up, you see how few offsets are available!!! Also, my Mustang II IFS kit came standard with 5x4.5. The hubs are super easy to re-drill, & I knew I had to have them machined to accept the rear disks anyway. 5x4.5 seems to be fords most common hub size (for full size vehicles), & it's been used for a long time. So I didn't fight it, & went with the 5x4.5. There's GAZILLIONS of wheel options, & offsets available for 5x4.5, so no special ordering is required.
[img]<a%20href="
http://s399.photobucket.com/albums/pp78 ... 5x4.5"></a>[/img]
This is the re-drilled rear hub.
By the way, Tim asked if they could be ordered in 5x5.5... Looking at the wheels, It doesn't look like there's enough meat left on the Flange to be drilled out that big...But I'm curious to see what the answer will be.
MIKE
