Will this hazard switch work in my 67? I want to move mine to the dash?
http://cgi.ebay.com/ebaymotors/EMERGENC ... 240%3A1318
hazard switch?
Re: hazard switch?
Yes, that's what you need. The wiring plug for your glovebox-mounted switch will plug right into it....though I have to admit I'm not sure if the wiring itself is the same, though I'd imagine it is.
Re: hazard switch?
i just checked a 69 harness i have here it is the same plug as int he ebay picture. so its the same. i think the problem you might find with moving the switch is will the wires reach from the glove box back to the dahs without too much trouble. i think what i would try is to untape the harnees and see if that would give the wires more room to come back towards the lower dash.
Re: hazard switch?
Thanks guys thats what I needed to know. Appreciate the answers!!
- 390F100
Re: hazard switch?
Keep us updated because my bump does not have a cargo light and that spot is empty so it would be nice to move the flashers into that spot. Let me know...
"There's no replacement for displacement"
1968 Ford F-100 2wd 390FE
1993 Toyota P/U 22RE
2001 Toyota Camry 2.2
2004 Toyota Solara 2.4
2007 Yamaha Vstar 650 Custom
2007 Suzuki S40 650
2007 Suzuki S40 650
Re: hazard switch?
good thing you said something about the cargo light. the flasher switch hole is a smaller hole on an original 70-72 dash. and that bezel for it needs an indentation in the dash for it to fit. heres a pic of that hole thats needed.
- 69F110
Re: hazard switch?
Fordman...dude, is your post count correct? 14000 plus? Holy cow brother.
I was reading the post and glanced over...about five seconds later my brain engaged...did that say 14000 something??? Holy moley.
Steve Davis
Pastor and U.S. Army Retired
- Lar4t9r
Re: hazard switch?
Fordman never sleeps...on the job 24/769F110 wrote:Fordman...dude, is your post count correct? 14000 plus? Holy cow brother.
Re: hazard switch?
thos enumbers were made laying around in testing testing last winter. probably over 10,000 or so in post pading . i also reply for fun some times. its not all business number in that count.
