C6 valve body diagram
- '75-4x4guy
Anyone have a blow up of the valve body showing the different valves and springs?
Jon
- 68F250
re: C6 valve body diagram
uh oh, sounds like you're already into it.
Barry
- '75-4x4guy
No not yet , the valve body in the c6 behind my old mans mild 460 is well -pretty lame .
I have a body from a '67 c6 that is in good shape and I want to install that .
I think I might mess around with the springs and maybe intall a shift kit .
I am looking very firm shifts .
Oh and by the way , thanks Barry !
Jon
- pat67shorty
- DuckRyder
Pin 7 and 9 to the bottom of the bores for VERY FIRM shifts.
- '75-4x4guy
"Pin 7 and 9 to the bottom of the bores for VERY FIRM shifts"
Robert what do you mean when you say "pin"
I heard once that stretching out the springs will give you a stronger shift feel.
Jon
- DuckRyder
Re: re: C6 valve body diagram
Cut a bolt or other solid clean object so that it fits above the piston (between the piston and cover) and holds them fully in. My TCI kit included one pin, but I ended up making another. Jay at Broader performance is the one that told me how to do it. Worked great!'75-4x4guy wrote:"Pin 7 and 9 to the bottom of the bores for VERY FIRM shifts"
- '75-4x4guy
What about just streching the springs out a little .
Would this also give the firmer shift ?
Jon
