How to tear down alternator for??
mljjones67
Post by mljjones67 »
Cleaning and painting the case?? It is a 3g. I took out the regulator and the case bolts, but the case wont come apart. Any ideas on how to separate?
LANCE65
Re: How to tear down alternator for??
Post by LANCE65 »
have you removed the pulley? I know that once you remove the pulley and the case bolts, the front half comes right off,not sure what retains the rear half?? Good Luck
-Lance
2015 Camaro-2001 GMC Safari-1984 F250 6.9/T19 2wd-1974 Dodge D100 short fleetside~ 72 wife ~ late model kids, a Chocolate Lab named Coco and a white rabbit named Marshmallow...now I need a ferret named Graham and I will have S'mroes!!!..lol :D
mljjones67
Pulley is removed.
tap it with a hammer to see if the bearings are just tight and sticking it from removing.
mljjones67
What exactly is the alternator case made from? It seems to be a aluminum. I am trying to figure out what to use to clean it up real good and paint it.
its eithe aluminum or magnesium.
mljjones67
Well i am guessing it is magnesium. The case has white powdery spots all over it. Wonder what would work good to get all that cleaned off.
I was able to get part of the case off, but unable to get the guts out of it. I was thinking of hot tanking the case to get it real clean.
thanks for your input Fordman
LANCE65
Post by LANCE65 »
Try magnesium wheel cleaner and a green scotchbrite pad, OR have it bead blasted with the bearings removed. Good Luck
-Lance
