Differential Question
dcbullet
Post by dcbullet »
Hi:
I found a complete Ford 9-inch rear end at the pick-n-pull. When I turn the driver's side drum, the driveshaft turns. When I turn the passenger's side drum, the driveshaft does not turn.
Is this normal? :hmm:
I don't know much about diffs.
Thanks in advance.
68F250
re: Differential Question
Post by 68F250 »
Sounds normal for a open differential. Does the other side turn backwards?
Barry
dcbullet
Post by dcbullet »
I don't think it did.
68F250
Post by 68F250 »
Well I'm no expert too but I would think either the driveshaft would turn or the other wheel would turn backwards.
Trying to visualize what the spider gears are doing only makes my head hurt. :hmm:
Better get some other responses.
Barry
dcbullet
Post by dcbullet »
lol. OK thanks. :-)
