hello to all. This is my first post and I'm looking for a little. I have a 68 ford f100 Ranger that I am restoring. I bought a tilt steering column for a 79 bronco that I would like to put into it. Could someone help me with matiching the wiring on the column from the f100 to the bronco? It doesnt have cruise control if that makles a difference.
Thanks,
Tico
Tilt teering on 68 F100...Help
Re: Tilt teering on 68 F100...Help
Check out all the tech tutorials on the home page. Good Luck
-Lance
-Lance
2015 Camaro-2001 GMC Safari-1984 F250 6.9/T19 2wd-1974 Dodge D100 short fleetside~ 72 wife ~ late model kids, a Chocolate Lab named Coco and a white rabbit named Marshmallow...now I need a ferret named Graham and I will have S'mroes!!!..
Here is the link to the page http://www.fordification.com/tilt.htm and at the bottom it has where a member lists which wire colors go to what.
I see that the 71 to 79 wiring is just about exact but what about the 68? would it have the same color scheme?
I can't tell you that but you should be able to compare the wiring diagrams between the 68 and 71 that Keith has on the home page.
Most of the wiring is identical on the bumps.
maybe this will help
thanks for the help I apprecaite it.
