Steering Wheel Pics
peanutman
Re: Steering Wheel Pics
Post by peanutman »
It comes with a black hub cover goes over adapter that the wheel bolts to and a rubber boot that hides any gaps, you can kinda see both looking thru bottom left of picture of wheel, but yes it does match up.
I can't remember if hub came with wheel or install kit.
wt4speed#2
Post by wt4speed#2 »
This is what the PO had installed when I bought the truck
This is what is replacing it.Thanks greg(TEXAS 70 RANGER XLT)
kaptnkaos wrote:Hey Peanutman,
I like yer wheel too... does the hub match up with the column collar ?
The ones I have seen like that that, the hub is larger than the column.
KaptnKA 8) S
Hey Kap this is how I resovled the gap problem between the black hub cover(the off colored silver piece) and the stock steering connector(where the blinker arm goes in)Is the bottom end of a jiff or peter pan plastic container. I just cut it off to lenght needed and cut the flat bottom to the corrct size so it would stay in place and painted it silver from the inside. Just plain ole redneck logic.
Went out and took these pics just for this thread. Hope they help
Tony B.Image
DFW Area
"Someday...
I hope you to get the chance,
to live like you are dying"
Member#'s 236 & 403
Úlf the Comedy Sidekick
wt's ride
thebucket
peanutman
Post by peanutman »
wt4speed#2 wrote:This is what the PO had installed when I bought the truck
http://i201.photobucket.com/albums/aa28 ... eel001.jpg
http://i201.photobucket.com/albums/aa28 ... eel003.jpg
KaptnKA 8) S
http://i201.photobucket.com/albums/aa28 ... eel002.jpg
hey 4speed and kap, For whatever reason i didn't have that problem. My column is a 72 3 on tree ps, may be the difference. I do remember installing and pulling it off several times until i got it right. A real pia for such a small project. :doh:
kaptnkaos
Post by kaptnkaos »
Hey tony...
Very creative way of dealin' with that... that's somethin' I would do for sure...
I like the look of the "Banjo" type wheel... I prolly won't change mine since I just got it, but if I ever get tired of it, I'll go with one of those...
KaptnKA 8) S
papabug71
Post by papabug71 »
flatblack wrote:
i found that steering wheel at a thrift shop for 3.00, i always wondered what the horn button looked like
and when i searched superior performance products and "the 500" i didnt find anything
thanks for sharing :D
Here is a better pic of the horn button flatblack. I see them every now & then on ebay. :thup:
Matt
Mine since 5/7/'94
302 / 3 speed / 3:25's
Brokenarrow
Post by Brokenarrow »
papabug71 wrote:Im currently running a NOS wheel I originally got for my Duster. Its (was) made by a company called Superior preformanc products which was bought out by Grant in the 80's. Its called "The 500". Looks just like the Grant wheels of today, but the SPP wheels had 4 holes in the spokes, the one Grant makes today only have 3 holes. It will do untill I get my new Ford wheel from DC :D
I dont know why the foam looks white in this picture, must be the flash. Its nice & black in real life tho.
14" no power steering = fun to turn at a stand still, thats for sure!!
http://i42.photobucket.com/albums/e340/ ... ORD010.jpg
I've got the same wheel on mine. It's been modified it to use a standard Ford horn button. I took this wheel off of a junked '67 f100 in 1981. It's been on 4 different trucks since then. :lol:
'68 SWB f100, 401ci FE/C6, '68 Mustang fastback (restoration in progress)
2013 F150 KingRanch (ecoboost), '48 8N tractor
"Be more concerned with your character than your reputation, because your character is what you really are, while your reputation is merely what others think you are."
— John Wooden
papabug71
Post by papabug71 »
Thats pretty slick! I have a couple of them horn buttons layin' around in the shop. I might try that. :thup:
Matt
Mine since 5/7/'94
Brokenarrow
papabug71 wrote:Thats pretty slick! I have a couple of them horn buttons layin' around in the shop. I might try that. :thup:
I used the horn-button mounting plate from a stock steering wheel. You have to drill out 3 spot welds. Then I drilled 3 more holes in the plate to properly index the button and bolted it on the wheel with the 3 existing bolts. Piece of cake :thup:
— John Wooden
mike68merc
Post by mike68merc »
Very Clever. :thup: Good Job!
That'd look good on MY old steering wheel!
I ordered the 4 spoke Halibrand wheel pictured above last month, but sent it back for the 3 spoke (wide hub) on the left (below)
I'm using a '79 Tilt column with the larger diameter Hub & thought it'd look better without a reducer. :maybe: I figured these wide hub versions would more "organic".
But now I'm imagining the old small hub, 4 spoke Halibrand (that I just exchanged) with the original Mercury center cap!!..... :hmm: (looks just like your FORD, but has the gear & lightning bolt symbol instead).
Way to go MacGyver!
flatblack
Post by flatblack »
http://img.photobucket.com/albums/v260/ ... G_0415.jpg
thanks ill have to keep my eye open for one on ebay, right now im using a copenhagen tin, looks awesome ill have to post a pic
Nitrous is like a hot girl with std's... you know you want to hit it but your afraid of the consequences
marz68
Post by marz68 »
texrodder
Post by texrodder »
Nice column Marz.Is it a univeral or idits specific fit for bumps?
marz68
Post by marz68 »
Thanks! this is a universal one from ididit. The one made for bumps sits more to the left, like a stock column does which is something I don't like so I got the universal one and moded the mounts to center it up.
wickedinhere
Post by wickedinhere »
Came in today
You can pay more but you cant buy better.
marz68
Post by marz68 »
Hey wicked that looks nice a super light!!
