On a '71 F100 automatic column...How many wires does the turn signal switch have? Can you tell me what color these wires are and what they control? Thanks for the help.
agouge
Turn Signal switch wiring???
Re: Turn Signal switch wiring???
here is a almost correct wiring for the wires that come out of the column. i do not know what year this is from but should be real close as colors. you can trace these colors in the diagrams here http://www.fordification.com/wiring.htm
