Carpet on my kick panels.
drytoast
Post by drytoast »
I got a bug up my but and decided to hide the ugly on my kick panels(I think thats what there called). I think it turned out rather good. The edge of the carpet is under the door weatherstrip to help hold it while the silicone dries, the carpet is bound all the way up the door edge. Now I have to get some carpet for the floor.
2005 Chrysler T&C Limited
mljjones67
Re: Carpet on my kick panels.
Post by mljjones67 »
Looks good.
JMcTurnan
Post by JMcTurnan »
WHat are those kick panels for anyway?
Lar4t9r
Post by Lar4t9r »
JMcTurnan wrote:WHat are those kick panels for anyway?
A place to mount the vents, for one thing. :wink:
fireguywtc
Post by fireguywtc »
ya know when I saw the tltle to the thread, I though how good will this look? But, when I saw it I was plesantly surprised how well it looks. Nicely done! :clap:
I had to cut out and rust repair my kick panels and weld in new sheet metal. If I cant get them to look good with my amature body work skills, I will definetly be doing this. I would imagine it would help with noise also. :dk:
Bill
mljjones67
Just a suggestion, but you might want to use contact cement when you glue it on or go to a carpet store and get carpet glue. My old man owned a carpet store for 30 years and thats the way we did it.
JMcTurnan
Post by JMcTurnan »
Vents for what? All there is is a blank space behind mine, no heater vent or anything?
towtruckerfour
Post by towtruckerfour »
The carpeting on the panels looks really good.
Troy
drytoast
Post by drytoast »
JMcTurnan wrote:Vents for what? All there is is a blank space behind mine, no heater vent or anything?
They are fresh air vents.
the kcik panels keep the weather out of the cab. if they weren't there it would be a hugh hole there instead o f a piece of metal.
flyboy2610
Post by flyboy2610 »
You don't happen to have a pattern for the carpet, do you?
I like that look! :thup:
Happy_Camper
Post by Happy_Camper »
Your carpet job ROCKS! :thup:
On my '72 that black plastic vent, helps chop up all the leaves trapped in the fresh air ducting before they blow through the cab and out the windows. This creates an environmentally correct confetti parade as I drive down the road. :lol:
When you have a shell on the bed, you have to get creative in order to have leaves blowing out. :evil:
Scott
1972 F250 Explorer C/S, 390-2V, Dual exhaust, C6, Goose neck ball in bed
New and improved with Tilt Wheel, Intermittent Wipers, 2005 Bench seat and 5th wheel camper!...
Life is *very* good!
MAK
Post by MAK »
Looks good. I was considering doing that to mine but wasn't sure how it would look. May give it a try now. :thup:
drytoast
Post by drytoast »
Thanks for the compliments. If you guys decide to try this I got the carpet at wal-mart ($20.00 for a 5'x7') and its bound all the way around it so I cut it out so the bounding goes up the weather striping for the door. I made a pattern using paper and tape, tracing and cutting until I got a near perfect fit.( I still ended up triming the carpet after I cut it out) Do the passenger side pattern first so you can cut it up to fit the drivers side. I used silicone for glue and it seems to hold up real well and quick so your not holding it there until it sticks,the only problem is you get a little high or a headache from the fumes until it dries. Just make sure you have your pattern going the right way before you cut the carpet or its going to be backwards.
Good luck Toast
1971ford
Post by 1971ford »
nice! i think i may do that :thup:
-Ryan
