Seat replacment
theskytoucher
Seat replacment
Post by theskytoucher »
Well my 4 year search for a replacement seat for my 68 f-100 has drawn to a close. A guy from work gave me a set of seats out of a super duty ford plus a brand new rear bench seat out of a super duty ford, well i decided i would try to mount the new seat into my 68. and it is as close to a bolt in installation as i think you could ever ask for. All the measurement are exactly the same between the seats, the width the depth even down to the distance between the floor brackets, and even more exact were the mounting hole for the brackets are in exactly the right spot the only thing that need to happen is the holes on the seat are tapped so they had to be drilled out once that was done it just bolted right in!! Just thought i would share my discovery with all of you!!
-Troy-
1996 Dodge ram 1500 4x4
1976 Ford F-150 4x4
Quando Omni Flunkus Mortadi
When all else Fails Play Dead
Re: Seat replacment
do you guys see this. its not that big of a deal to put different seats in your truck. just choose what you like and go for it.
James72
Re: Seat replacment
Post by James72 »
Are you useing super duty buckets or bench? I've got a set of super duty buckets in the front of my crew and the matching bench in the rear. The front is still not right, they sit about 2" too high, the rear bench pretty much fell into place. I'm wondering how you mated buckets to stock brackets, if we're talking about front buckets here
James
'05 Mustang GT
'72 crew 4x4
'07 KTM 450 xcw
2006 F350 CC Diesel 4x4 Lariat
theskytoucher
Re: Seat replacment
I am talking about the back bench seat going as a front seat into the bumpside!! And i used the stock bumpside brackets and everything lined up perfectly.
-Troy-
1976 Ford F-150 4x4
Lar4t9r
Re: Seat replacment
Post by Lar4t9r »
theskytoucher wrote:Well my 4 year search for a replacement seat for my 68 f-100 has drawn to a close. A guy from work gave me a set of seats out of a super duty ford plus a brand new rear bench seat out of a super duty ford, well i decided i would try to mount the new seat into my 68. and it is as close to a bolt in installation as i think you could ever ask for. All the measurement are exactly the same between the seats, the width the depth even down to the distance between the floor brackets, and even more exact were the mounting hole for the brackets are in exactly the right spot the only thing that need to happen is the holes on the seat are tapped so they had to be drilled out once that was done it just bolted right in!! Just thought i would share my discovery with all of you!!
What year super duty did the seats come out of? :?
Happy_Camper
Re: Seat replacment
Post by Happy_Camper »
OK, I am totally at the edge of my seat on this! :woohoo:
could you please post some more info, and a picture if possible. This would be a huge help for me, and hopefully others.
Thank you very much! :thup:
Scott
1972 F250 Explorer C/S, 390-2V, Dual exhaust, C6, Goose neck ball in bed
New and improved with Tilt Wheel, Intermittent Wipers, 2005 Bench seat and 5th wheel camper!...
Life is *very* good!
theskytoucher
Re: Seat replacment
All super duty's will work (99-09) all the back seats bolt in the same!! All the info there is to give is pull the rear bench seat out of a super duty unbolt the brakets drill out the tapped holes the brackets bolted to and install bumpside brakets to those holes bolt new seat into old truck!! Easy as that!
-Troy-
1976 Ford F-150 4x4
1967AceStroker
Re: Seat replacment
Post by 1967AceStroker »
That looks so good, and I can't believe it just drops right in! Quick question though, is that style from a extended cab superduty, or a crewcab superduty, or are they the same?
My Project Thread (Not updated in years.)
1967 F-100, Shortbed, 351W - 72mm Single Turbo - Megasquirt MS3x Engine Management, Tremec TKO 500, Ford 9" - Strange Nodular Center Section - Strange 35 Spline Axles - Strange Full Spool - Caltracs - DJM Drop Kit, Crown Vic IFS Swapped - 2 Coils Cut, Power Steering, Power 4 Wheel Disc Brakes, Paint - Kona Blue
Happy_Camper
Re: Seat replacment
That looks awesome! Thanks for the details. As a bonus most rear seats get very little use, so the foam should be in better condition. I've all ready started a search for one. :hd:
Thanks amigo! A cyber beer to you :thup:
Scott
fireguywtc
Re: Seat replacment
Post by fireguywtc »
1967AceStroker wrote:That looks so good, and I can't believe it just drops right in! Quick question though, is that style from a extended cab superduty, or a crewcab superduty, or are they the same?
I can tell that is out of a crew cab and back seat. A super cab is real small and proabably wouldn't fit since they are 2 seperate pieces, seat and seat back. I really like this idea and think I am going to keep an eye out. A back seat like my superduty folds 60/40 and has a fold down armrest/cupholder in the seatback.
I do have a complaint though. Since 05+ models put a folding cargo metal shelf that goes under the rear bench, it takes away from the comfort, My back seat is a little firm for my taste on long trips because the foam is thinner due to the making room for that metal shelf. The 03/04 didn't have that cargo tray and I think they have more cushion for the seat and the fold down armrest/cupholder.
Finally I did see someone who was selling their F-250 in the classified thread. They had put King Ranch style rear bench seat in his truck. It looked good with that cow hide leather!!
Bill
FreakysFords
Re: Seat replacment
Post by FreakysFords »
I'm parting out an 05 crew and I bet I've looked @ that rear seat a thousand times thinking it would be nice if it would look decent in the bump! I just didn't want to fool with having to lower one so the back didn't set to high or such nonsense. Never even tried it, didn't want to get disappointed.
THANKS for the info!!!!!! And more importantly, the pics! I'd have read the post and thought "yah, but looks like crud".
That seat's coming out tomorrow and getting the cover pulled for a recover.
Darlin 69 Ranger 390 4v, PS, DS II, disc front, 3G alternator, 67 mirror.
warponyxlt
Re: Seat replacment
Post by warponyxlt »
what about the door latches in the arm rests they look the same as the ones in a bump i never took the super duty door apart but they look the same just my :2cents:
if its fixed break it again red white and ford blue the only up hill thats good is the one you are going down
Joshpow
Re: Seat replacment
Post by Joshpow »
Not sure of the superduty door latch handles, but mine are from a Ford Econoline Van. The 80's vans have them on all doors. They are chrome and identical to ours. Sme newer ones have them on the back doors if they are work series vans. I believe they are black plastic. Just my :2cents: hope it helps.
Josh
72 F-100 Ranger XLT SWB
71 F-100 Custom SWB
67 F-350 Dually Dump
02 F-250 Stroke
Re: Seat replacment
yes the econolines ahve the same door latches from the 80's and into the 90's. i just scored a nos set of them on ebay for a van. they are the same as the bumpsides.
FreakysFords
Re: Seat replacment
Well, sadly my seats are toast in the 05 (didn't hurt to hope). This was a flood truck so chances weren't that good but now that I know, I will be on the lookout. Thanks again for the info!
