Gas Tanks
MadMaxetc
Gas Tanks
Post by MadMaxetc »
I want to put a new tank in my 67 but I don't want it in the cab.
I would like it under the frame but don't want to relocate the support for the mustang tank.
I could weld one up...OR...I could lay one up.
What do you guys think about a fiber glas tank? I could design a nice one in CATIA and make the molds out of foam. Then just kay it up and bond it together.
FORD Girl
Photobucket Pictures
Re: Gas Tanks
the onyl question i have about fiberglass and gasoline is wil they work together ok? will the fiberglass crete any sort of static chrge? i doubt it but it was a thought. why not try for a midship tank. they can be had from dentsides.
MadMaxetc
Re: Gas Tanks
Post by MadMaxetc »
fordman wrote:...why not try for a midship tank. they can be had from dentsides.
I have not realy looked, but I have not seen any in the yards here.
If you find one let me know. I want to put the filler into the bed too.
FORD Girl
Re: Gas Tanks
they crushed everything last summer. so everything is new here again. i am waiting to jump on another dentside as soon as it comes in. the only thing up here no is in the early 80's
68 BB Bump
Re: Gas Tanks
Post by 68 BB Bump »
Here's an option if you don't mind a little modifacation. A racing fuel cell.
1968 F100 460 C6
1976 Jeep CJ7 AMC 401 (It's not a bump but it likes bumps/rocks)
2008 Pontiac Solstice GXP
la1031
Re: Gas Tanks
Post by la1031 »
I did a fuel cell too, but I have not cut a fill hole yet or added a sending unit. I should clean my truck before I take pictures...I swear everything is new..
http://s446.beta.photobucket.com/user/1968F100/library/
1968 F100 Shortbed
302/306 roller, C6 w/shift kit
3.70POSI w/trackbars
Hydro-Boost
Hoping for 13's and looking good doing it !!
Makita Industrial Power Tools
Tools for the long run.
la1031
Re: Gas Tanks
Post by la1031 »
1968 F100 Shortbed
Hydro-Boost
mike68merc
Re: Gas Tanks
Post by mike68merc »
This 20 gallon Poly tank came on 73-77 F250 Highboys & Super Camper Specials (they had the narrower frame like ours).
Fits between the frame rails, sits in a metal SKID PLATE type pan (for support & protection) & if you grab all the brackets it goes in pretty easy.
....Also uses a FORD sending unit! :wink:
I've mounted it level with the bottom of my frame for clearance since I raised the bed floor. Otherwise it would hang down that much.
Fill will be in the side of the bed for me.....Could come up through the floor or even inside on the bed wall?... :hmm:
Personally I'd rather have a custom fuel cell like these other guys have, but the tank was only $50.00 at the wrecking yard. Fuel cells cost a bit more.
This link talks about it a bit:
http://www.fordification.com/fuel-tank01.htm
