arm rests
aramil
arm rests
Post by aramil »
what do you guys think of these?
http://www.parts123.com/parts123/yb.dll ... Z50000029b
i think some custom arm rests would add a nice touch to the interior.
72, f-100 ranger xlt, 360-c6, 2wd 84k miles.
77, ford f-150 custom 4x4, 400m-c6 SOLD
"the existence of flamethrowers is proof that someone, somewhere, sid to himself, "i want to set those people over there on fire, but i dont feel like walking over there to do it"
seattle67
Re: arm rests
Post by seattle67 »
You bet, if you want more of a "custom" look to the interior, those would probably be cool.
aramil
Re: arm rests
Post by aramil »
that company also sells these,
i have an aunt thats good with sewing and such so if i used a design and built it she would be able to cover them. its just getting the materials i need and everything that could be the hard part..
Re: arm rests
i had considered gettign a block of wood and carving it down tot he same shape but smaller. and have it wrapped in foam and vinyl. enough to make it the same size as the orginal.i don't know how it would work. but it might work out you never know.
aramil
Re: arm rests
Post by aramil »
thats what i was kinda thinking fordman, im just looking for a design that i like enough to try and emulate(sp?) it and make it work for my truck. the only problem i can see would be mounting it unless you butcher the mounting points out of an old pair of stock arm rests, or make a bracket or somthing that will work, i think you could take that bottom design that doesnt have the fancy metal piece and use some foam to make it work like a wider longer version of the stockers.
