Seat replacment
- michael69
Re: Seat replacment
Do these seats fold forward to get at tank or storage. I have never even looked at one just wanting to know so it can join my list of seats to look out for. Also what years have the fold down armrest and cup holders. THANKS ![FORDification Rocks! :fr:](./images/smilies/icon_FORDification.gif)
Michael69
1985 CJ 7 jeep w/35s
1967 SS Chevelle 502 4 speed
Re: Seat replacment
he's got a real good question, anyone know? Do these seats you're talking about (out of crew cab or whatever) fold forward to access behind them? I'd like to know too?
- fireguywtc
Re: Seat replacment
Yes the superduty bench seats from the rear of the crewcab fold foward all the way down. Also I think all years had the cup holders available in the rear seat, but it depends on trim level. I believe XLT and better have cup holders, XL does not. I know for sure 03+ had them in the back on XLT+
Bill
Re: Seat replacment
Just curious, where/how do you guys find yards with newer vehicles in it? Most of the yards around here have 1990 and older vehicles. Anything newer is usually not there or its for "non-public" pickins. ![Hmmm :hmm:](./images/smilies/icon_hm.gif)
1970 F250 Camper Special
- fireguywtc
Re: Seat replacment
They are hard to find for sure. Most are bought back and hawked for the expensive stuff like the good seats and the diesel motors, ect.BiggDogg wrote:Just curious, where/how do you guys find yards with newer vehicles in it? Most of the yards around here have 1990 and older vehicles. Anything newer is usually not there or its for "non-public" pickins.
Here is one place I found when I used to live in Cali. I don't know if you are near it but they do a ton of super duty parts.
http://www.subwaytruckparts.com/
Bill
Re: Seat replacment
Great link fireguywtc thanksfireguywtc wrote:They are hard to find for sure. Most are bought back and hawked for the expensive stuff like the good seats and the diesel motors, ect.BiggDogg wrote:Just curious, where/how do you guys find yards with newer vehicles in it? Most of the yards around here have 1990 and older vehicles. Anything newer is usually not there or its for "non-public" pickins.
Re: Seat replacment
Newer truck parts in Socal:
www.pickupsalvage.com
They're a dismantler so it's already pulled you just have to pick it up. A little expensive but at least they have parts.
03 Chevy S10 - the daily driver
68 Ford F100 longbed - the tow pig / TLC project
78 Chevy Impala - the race car
I'm sorry if I ask lots of questions, there's just a lot of stuff I don't know (yet).
- 1967AceStroker
Re: Seat replacment
Well, not all of these superduty seats will work. I just bought one today and it doesn't fit, as far as being a drop in, I am going to have to weld in some square tubing to mount it. The seat is from a '99 to '04 crew superduty, not sure of the exact year, cause the driver's door was gone and I don't know how to tell each year apart in this body style. The mount bars are different than the ones skytoucher used. They are 52" wide and need to be 42".
![Image](http://i518.photobucket.com/albums/u350/Mr-Toast/Truck/IMG_0149.jpg)
My Project Thread (Not updated in years.)
1967 F-100, Shortbed, 351W - 72mm Single Turbo - Megasquirt MS3x Engine Management, Tremec TKO 500, Ford 9" - Strange Nodular Center Section - Strange 35 Spline Axles - Strange Full Spool - Caltracs - DJM Drop Kit, Crown Vic IFS Swapped - 2 Coils Cut, Power Steering, Power 4 Wheel Disc Brakes, Paint - Kona Blue
Re: Seat replacment
I have a rear seat out of a 02 Superduty.
You must have to change the track or something so the seat will move back and forth?
Back seats dont adjust?
- michael69
Re: Seat replacment
Yes you have to replace the tracks with the tracks from your bump seat, but what he is saying is you can't just swap tracks because the mounting holes is to wide on this seat.
Michael69
- 1967AceStroker
Re: Seat replacment
Well his seat is differnt than mine, cause his bump brackets bolted right on that seat, mine are too wide. He said he just drilled out the tapped holes, mine had no tapped holes, and the rails looked different. Must not all be the same for that body style super duty. And I had to make some cross bars in between so I could mount my bump slide brackets to the seat. I will post some pics when I finish it. ![Doh :doh:](./images/smilies/icon_doh.gif)
- michael69
Re: Seat replacment
1967AceStroker when you post pics can you get one of the bottom of seat so I can see how you make the mounts for your tracks in case I get that same seat and have that problem. THANKS MAN ![Thumbs up :thup:](./images/smilies/icon_thumright.gif)
Michael69
- 1967AceStroker
Re: Seat replacment
Sure, I will put pics and a description when I finish. I tried tack welding some 2x2 square tubing I had laying around, but I cut it off cause the seat would have set too high. So I went to a friend who makes trailers and he said he would give some 1x2 square tubing, just have to wait till tuesday to pick up. I carefully took measurements off the seat when I test fitted it. And it will be welded flush up inside of the stock mount bars on the new seat.
- FLATBEDFORD
Re: Seat replacment
I just found this on Craig's list.
http://newyork.craigslist.org/fct/pts/1098176120.html
How can I tell if this will work easily like it did for skytoucher, or if it will need modification? Looks like it would be nice.
My Photo Gallery
My Photo Gallery
- Happy_Camper
Re: Seat replacment
I took a drive up to a couple of "recyclers" that specialize in pickup trucks. Subway parts, and Cordova truck wreckers. The guy at Cordova was great to work with. I showed him the pictures of Skytoucher's seat install, and he explained that the seat is pre-Superduty (or pre-'99). As the picture cuts off the part of the folding handle, he couldn't tell the year. He explained that prior to the Superduties the seat frames were almost drop in from the '60s on up, because they had a 42" wide mount. He also explained that these seats in good condition are getting hard to find. He didn't have any, but had a bunch of front and rear from '99 and up (all of which have a 52" wide mount pattern). So he showed me the differences. He said, on pre-'99 front or rear will work. After that, it's a matter of modifying the frames.
So much for the Superduty seats as being an "easy bolt in".
But it's always a great day to hang out around cool truck parts ![Thumbs up :thup:](./images/smilies/icon_thumright.gif)
![Sad :(](./images/smilies/icon_sad.gif)
Scott
1972 F250 Explorer C/S, 390-2V, Dual exhaust, C6, Goose neck ball in bed
New and improved with Tilt Wheel, Intermittent Wipers, 2005 Bench seat and 5th wheel camper!...
Life is *very* good!
![Image](http://i104.photobucket.com/albums/m184/66Runt/1972%20F250%20Explorer/Happy_Camper_sig_pic.jpg)
