I just did my 3G conversion today and so far so good. I do have 1 question...There is a 3 wire plug near the starter solenoid, BIG balck w/yellow stripe,red,and yellow.('71 Ranger F250) They all seamed to wind up at the same place,so I just combined them all and hooked them up to the solenoid bat side. Is that OK? Here are a few pics..OH and I did the headlight relays. ENJOY....
-Lance
3G done
3G done
2015 Camaro-2001 GMC Safari-1984 F250 6.9/T19 2wd-1974 Dodge D100 short fleetside~ 72 wife ~ late model kids, a Chocolate Lab named Coco and a white rabbit named Marshmallow...now I need a ferret named Graham and I will have S'mroes!!!..
Re: 3G done
WOW! I just took it for a test drive, what a difference. It even seems to run smoother.
-Lance
-Lance
Re: 3G done
Did you tap the existing the Red/Green wire with the 3G red/green wire?
Re: 3G done
The BIG black w/yellow stripe is the Main Power wire to the cab/ignition switch.
The Red and Yellow wires should be for the Amp gauge which probably wont work with the new alternator/wiring.
What did you use for the Alternator fuse and where did you get it?
Re: 3G done
This where I purchased mine.
http://rjminjectiontech.com/?p=7
Scroll down to see this one
Alternator Charge Cable Kit $40.00
5ft of 2 gauge heavy duty EPDM cable rated -60°F to 220°F, super flexable, resistant to flame, oil, abrasions, tar and grease.
Mega-Fuse holder
2 - 175Amp Mega-Fuses
Red Protective Boot for Alternator connection
4 lugs (3/8″ for Battery, 1/4″ for Alternator, 5/16″ for Mega-Fuse)
Red Adhesive Lined Heat Shrink
Solder Pellets
Mega-Fuse holder
Solder Pellets
Re: 3G done
I used a BUSS 150a waterproof circuit breaker. And yes I tapped the green/red wire. I am very impressed with how easy it was,and how well it works.
-Lance
-Lance
