What color to recover my seat in?
68monster
Post by 68monster »
I am having a time trying to figure out a color to redo my seat in. I am thinking of doing a med tan in vinyl with a lighter inner.
this is the inside color
this is my ext color
I have a bench seat that i am recovering i will be using the stock pattern . also what do you think about having flames quilted into the back of the seat instead of the ribs?
My door panals will be wooden like this but not stained just lacquered.
1967,1968,1970 4x4 ranger!
thebannister8
Re: What color to recover my seat in?
Post by thebannister8 »
white, blue and the wood color......what to accent.....personaly....i'd make the whole interior white and the lighter color of the unstained wood might go well....flames anywhere are cool :)
1967AceStroker
Post by 1967AceStroker »
Gray. Its a nuetral color that would look good with what ever color you decide to go with. That exterior color in that pic is what I am going to paint the interior steel and the body with on my truck, with a gray seat and carpet. Tan on tan does look good for the interior though, If the steel will be tan, go with a tan seat.
My :2cents: .
Do you have any more pics of that blue truck? If so, could you pleaze post them! Thanks.
My Project Thread (Not updated in years.)
1967 F-100, Shortbed, 351W - 72mm Single Turbo - Megasquirt MS3x Engine Management, Tremec TKO 500, Ford 9" - Strange Nodular Center Section - Strange 35 Spline Axles - Strange Full Spool - Caltracs - DJM Drop Kit, Crown Vic IFS Swapped - 2 Coils Cut, Power Steering, Power 4 Wheel Disc Brakes, Paint - Kona Blue
68monster
Post by 68monster »
I don't know if i have more pics of my blue truck, i could take some of how it looks now, but the restore that i did was ten+ years ago so she has aged pretty bad. hey live and learn, i am going to do the truck a little darker than the color in the pic. just for you info the color i sprayed is called spectra mica blue it is a 85 Toyota truck color. (i don't know if that is how you spell it)
1967AceStroker
If you have any pics of it at all that would be cool. It helps me visualize what mine will look like finishd. For me it was a toss up between the toyota/lexus spectra mica blue, and ford dark blue pearl metallic clearcoat. I decided to go with the ford dark blue pearl, its a little darker than the spectra blue, but with a more noticable pearl and metallic effect. If you go to a ford dealership you can see that color, its on the f-150, fusion, explorer, that I know of, go when you have good sunlight to, it shows off the pearls and metallics good.
68monster
Post by 68monster »
the blue truck that i posted is my truck that i did 10 years ago in spectra mica blue
68monster
Post by 68monster »
what do you think? i want to replace the stock badge with the 390 side marker badges.... tacky.... coool????
mrsnicks
Post by mrsnicks »
I'm going to pick up this seat tomorrow. I'm getting it for $100.00 bucks off craigslist. Not sure the exact year but it's out of a late model F250. It has a poorly repaired rip but I can live with that until I have the panel replaced or repaired better.
Patrick
Chevrolet
1969 F100 4X4 Highboy 390 3sp
1969 F100 SWB 2wd Auto 351w
1972 F100 Ranger XLT 302 Auto
http://mrsnicks.blogspot.com
cdeal28078
Post by cdeal28078 »
I like those wooden door panels. As a woodworker I have often thought of how to best make a set of wooden panels. Is the Sapele Mahogany?
I like those alot and might try a set this winter
clint
71 F100 SportCustom
1986 Bronco 5.0 AOD
67_p_car
Post by 67_p_car »
68monster wrote:I am having a time trying to figure out a color to redo my seat in. I am thinking of doing a med tan in vinyl with a lighter inner.
dark blue with lighter tan inserts - forget the flames - cool enough, but really?
1966 Beacon
1968 Ford F100
1967 Porsche 912
2002 VW Jetta TDI
St. Paul — Zumbro Falls, Minnesota
