Windsheilds
- FormerMarine1981
re: Windsheilds
Thanks for the tip Fordman.
But about the gaskets was anything found out? I need one so I can put the chrome trim back in. I was stationed away from my truck when the windshield got put back in and someone told my dad that you can not put the trim back in with a new windshield.
you can put the trim back in the new gaskets. you are suppose to do it before the gasket is installed. it is very hard to put the trim back in after the windshield is installed. . i have never done it but my dad did and he said it was a b. i have seen where others here have said that they broke there windshield tring to put the chrome in after the glass had been installed in the truck. the easiest route would be to get a new gasket and start over. i would cut the exsisting gasket out instead of trying to save it . the choice is yours.
- 69bumptruck
re: Windsheilds
I had the windshield on my '69 installed by a friend, who did it as his profession. When he got there to do it, the only rubber he had was from a '73-'79. It has the chrome piece in it. I think he installed the chrome before putting in the glass. He did tell me that it was the most difficult install he had ever done!
re: Windsheilds
This looks like an old topic but:
This weekend the wife and I tried to put the windshield in my 68. My old one was cracked so I went to the yard and got a great window from a 75 f100. Well we cracked it trying to install it to. WEll last night I pulled it out and I dont think they are the same. The bottom of the dent side window curves out more than the old factory bump side glass did. The tops are the same though. I am not sure the window I got from the dent side was factory though. It was tinted at the top. None of the 70's trucks I haver ever owned were tinted at the top. But I do know they will not stack flat togeather.
- Bobaloo2
Re: Windsheilds
Before I go buy it, a 1968 F600 dumptruck windshield will fit my 67 F100, correct? They sure look the same, but I could not take any measurements.
Thanks. I know this one has been beat to death, but I cant find the exact answer in the search.
Bobaloo2
Bob Mayben
1967 F 100 SWB
1963 Bel Air 409
Bob Mayben
1967 F 100 SWB
1963 Bel Air 409
Re: Windsheilds
yes they are the same because the doors from the F600 will interchange as well as they have the same dashboard in them. make sure that the truck looks just like a bumpside though. if the F600 looks like a slick then it may not fit.
Re: Windsheilds
All '67-'72 F100-F600 windshields will interchange.
- flyboy71
Re: Windsheilds
For whats its worth, since we're on windsheilds, I removed mine and saved the gasket just in case. It is a real pain if you plan on saving the rubber at all. I ended up peeling a section back on the inside and for lack of anything better I slid a whole raft of drawer dividers in under until I was able to slowly peel the rubber away from the outside. Once you get a side and some of the top, it starts to pop out on its own. This is the only way to do this and keep it a one man operation that I found.
-Jeff
1971 F-100 240 straight six, 3 on the tree (parted out)
1972 F-100 302 auto trans, pwr steering, pwr brakes (under construction)
"Things are more like they are now than they ever were before" Dwight Eisenhower
- FormerMarine1981
Re: Windsheilds
Hey, as long as it worked. Might have to try that
Re: Windsheilds
the only one i ever tried to remove like that. was almost all the way out and then it cracked it when i was pulling the rubber one more time. so from now on i just cut the rubber off and trash it. its never any good on any of the trucks i have parted out.
Re: Windsheilds
Well coming from an expirienced glass man and windshield installer, more than likely won't interchange. They are from different series of windshields, luckily me it only costs me 90bucks to install one muwhahahaha.
