The Anti-Squeak-Plates between the seat frame and the floor of my 1967 F100 Ranger are missing. To fabricate a set of new ones I should know thickness as well as the kind of material (plastic? hard rubber?). Are these parts also used in case of a carpet?
Thanks
Roman
Seat Frame, Anti-Squeak-Plate?
Re: Seat Frame, Anti-Squeak-Plate?
it is real thin plastic stuff. i have only seen it once. i would think you would only need it if you are going straight to the metal floor of the truck. the carpet or even the rubber floor mat would act as a insulater and not be needed in those two cases. it was real thin stuff.
- seattle67
Hi Roman,
I bolted my seat frame directly on top of the carpet, no anti-squeak-plate, with no problems.
- thebannister8
mine sits on top of some tar type goo
- seattle67
That would be FoMoGoothebannister8 wrote:mine sits on top of some tar type goo
