interior carpet fit for 68 F100. will this work?
oldtexasdog
Post by oldtexasdog »
Will a pre-cut carpet kit for a 1980 F150 fit a 68 F100. Both 3 on the tree.
Thanks
Re: interior carpet fit for 68 F100. will this work?
the 3 spd has a low hump in the center. the 73-79 started witht the high hump on the trucks. so the 80-86 will have a high hump also. so the hump area will be too high to fit down over a low hump. unless it is cut in the middle and the excess trimmed off. then it might fit.
oldtexasdog
fordman wrote:the 3 spd has a low hump in the center. the 73-79 started witht the high hump on the trucks. so the 80-86 will have a high hump also. so the hump area will be too high to fit down over a low hump. unless it is cut in the middle and the excess trimmed off. then it might fit.
Bummer. :cry: Thanks. I found a new one for 25.00 and thought it might work. Oh well.
mk
Post by mk »
The 80-up cabs had both high and low humps like ours, fm. Just looked at an 82 cab out back and the low floor is similar but the tunnel seems to be a little rounder under the dash forward of where the high hump plate would mount.
mike
~Will Rogers
Mercury truck ID thread:
Ford truck model history:
Using dentside fender liners:
Matchbox diecast bumps:
oldtexasdog
Found another carpet but it was made for a 65 with gas tank outside cab? Everything else same. Would this fit?
a 65 what? F100? f350? f350 i don't think so. . f100 probably. f250 probably.
