Wiper upgrade
lee_ford
Wiper upgrade
Post by lee_ford »
The Truck Shop at Truckandcarshop.com shows to have an intermitent Wiper switch for the 73-79s which is what is needed to do this upgrade.
http://www.fordification.com/wiperdelay.htm
Anyone ever done any business with them?
My 1969 F100 Gallery
[Please note: A lot of what I write may be common knowledge to some of us. But for a new comer and even us at one time, somebody had to inform us that FIRST time.]
MotorDog
Re: Wiper upgrade
Post by MotorDog »
Actually, it is not only the switch, but you also need the "black box" which is wired in-line. The Black Box is what makes this thing work. I didn't look it up at the site you suggested but I'm sure they are extremely "pricey! One of our members here was selling the complete units, (used) for $15 plus about $5 for shipping to most U.S. locations. I got one and it works perfectly. Do a Search in the Interior section for "Interval Wipers" and you will probably find it. He may have more...Good Luck!
What ever happened to the age-old practice of just "Minding Your Own Business?"
lee_ford
Re: Wiper upgrade
Post by lee_ford »
Thanks Motordog,
I skimmed over the part in the Fordification writeup about where to mount the relay. At least I found the switch. :)
I'll look into finding the post about it.
I am still wondering about Truckandcarshop.com though.
knightfire83
Re: Wiper upgrade
Post by knightfire83 »
I have a picture of what Truckandcarshop.com offers below.
MotorDog is correct you will need the black box for it to work.
Auto Zone has the same switch for $43.99 / Duralast #SW1013
Advanced Auto Parts has it for $53.99 / BWD #S3579
Rock Auto $55.79 / Airtex #1S1020
Your best bet is to find a late 70's - late 80's Ford truck in a junk yard and pull the switch and box. 5 minutes and $5 - $10 later your all set.
:thup:
1970 Ford F250 4x4 ~ Sold.
lee_ford
Re: Wiper upgrade
Post by lee_ford »
I just checked the link in the writeup to Ebay. There are currently 4 listed for about $30. Thanks.
71PA_Highboy
Re: Wiper upgrade
Post by 71PA_Highboy »
You can use the ones up to mid 90's... You just have to move 2 wires around (they are for the washer). The earlier ones(early - mid 70's) are a direct plug in.
Hit the Junkyard and look for the early 90's Eddie Bauer Broncos... Look for the red connector and you will know you have the right one.
Get the box and the switch.
Usually run about $10 at the JY for the pair.
hth,
eric
Got Ford?
2 EarlyBroncos (68,69)
2 Classic Mustangs (69,70)
1 94 Ranger, 2.3, 5spd
1 Lincoln Mark VIII
Re: Wiper upgrade
i got one from a 90's bronco. i just moved the wire in the plug it was very easy. i found a torino switch on ebay. itlooks similar but i dont knowif it would work. it is at 3.99 right now. with one bidder. without the wiring and the box it is kind of useless though even if its the right switch.
lee_ford
Re: Wiper upgrade
Post by lee_ford »
71PA_Highboy wrote:... You just have to move 2 wires around (they are for the washer).
I have moved/repaired the wires in factory plugs before so should be easy.
Now if I just knew which wires... :dk:
Re: Wiper upgrade
the orange one. heres the link. http://www.fordification.com/wiperdelay.htm
lee_ford
Re: Wiper upgrade
Post by lee_ford »
Man, I need to quit being so short sighted. I forgot that 78-86 will fit easy. OK, it is off to a Junkyard. :drive:
Thanks guys.
Re: Wiper upgrade
lee here is one of those wiper delays. it came up in my daily ebay search today. i remembered we had been talkign about it so i put it on my watch list. so i could post the link here. this guy regularly sells these things. i have no experience with him but heres the link. there are other guys who regularly sell them also. i think one o fthe ebay names might be djoffroad or something similar to that.
http://cgi.ebay.com/ebaymotors/ws/eBayI ... MEWAX%3AIT
