cliiiiickkkkkk
- A_G
cliiiiickkkkkk
so the other day i tried starting my 67 f250 352 and just got a machine gune click.
so i replaced the fender mount solenoid. new one clicks but a stronger click.
Now the battery is shot, i know that, so ive been jumping it. Used to turn over now the solenoid click.
Starter possible locked?
I tried banging on the starter and nothing
Starter fried?
Thanks,
Anthony
Starter fried?
Thanks,
Anthony
"The happiness of a a man in this life does not consist in the absence, but in the mastery of his passions"
~Alfred Lord Tennyson~
Caterpillar Diesel Haul Truck Mechanic
- heep70
Re: cliiiiickkkkkk
Clean the connections? All of them including the dead battery connections that you jump to? All the ground connections from the starter back to the batt?
Greg
2000 Subaru Outback limited.
2013 Polaris Pro 800 RMK 163"
My last 1971 "Highboy" pics
Re: cliiiiickkkkkk
The dead battery is so dead that it's putting a huge drain on the power source from which you're jumping it.
Clean your connections and replace the battery and you'll be golden. (And yes, a battery can do that. If you leave it on a trickle charger overnight, you might be able to at least jump start it again, but it won't last long.)
Josh
'72 F-100 Sport Custom 4x4
- A_G
Re: cliiiiickkkkkk
yea i never thought of that. ive got another project arriving here in the next 4-5 days so ill just steal the battery out of that.
now ive used two trucks, and jump box to turn this over before.
today i tried with 2 chargers and my pickup and just a real strong click.
when i tried starting it last it kept getting close to starting, poping and such. so i held down the starter, for probably to long and i think i fried it. so this weekend when im fixing everybodys crap.
Brakes on my Moms car, springs on my truck. I might as well pull the starter, cause im know im going to forget soething and haft to go into town for it...so ill take it and have it tested while im at.
Re: cliiiiickkkkkk
Battery sounds like the culprit, but don't overlook the possibility that the new solenoid is bad as well.
Timothy
It's for my twin boys, sure they're only 3 right now, but it's all for them! Well, and my twin girls. They're not even 1 yet, but when they are I'll have a pit crew!
Toys:
62 Thunderbird Convertible
68 F250 Ranger 2wd - 390 C6
Toys:
- Salty
Re: cliiiiickkkkkk
+1 I had this happen to me with a starter before. Really messed with my head because I was thinking "there is NO WAY this thing is bad, it's brand new!".Old Bird wrote:Battery sounds like the culprit, but don't overlook the possibility that the new solenoid is bad as well.
Re: cliiiiickkkkkk
I find that your battery terminals and cables may not be heavily corroded so you see white power, but you can get enough corrosion that the metal is dull and it will REALLY affect a poor/low battery when trying to start it. I'd say buy a terminal/post cleaner (and not the brush kind) the kind that actually shaves/cuts off a thin layer of metal from the cable/post. If the battery cables are kinked or have exposed cable you could have corrosion anywhere along the cable itself so junk it and buy a new one.. I always get at least 2 gauge cables.
Patrick
Patrick
Chevrolet
1969 F100 4X4 Highboy 390 3sp
1969 F100 SWB 2wd Auto 351w
1972 F100 Ranger XLT 302 Auto
http://mrsnicks.blogspot.com
- Salty
Re: cliiiiickkkkkk
Cleaning up or replacing your grounds always helps too.
Re: cliiiiickkkkkk
I 3rd that as well, Bad battery's can (often) short out internally so when you try jumping them this internal short eats up more power then what tries to get to the starter + the size/length of your jumper cables also figures in to how much current will get there.mr_josh wrote:The dead battery is so dead that it's putting a huge drain on the power source from which you're jumping it.
Been lots of BAD "New" starter solenoids so don't be to surprised if it is bad after you put a good battery in.
Re: cliiiiickkkkkk
i hate batteries. but who would want to hand crank over a fe? or who could? maybe if you had a pony motor you could do it.
Re: cliiiiickkkkkk
Just went through this. Before you pull the starter, try hooking up jumper cables to the battery and jumping straight to the starter, bypassing the solenoid. Hook the hot side of the battery to the cable lug on the starter. Touch the ground end of the cable to the body of the starter. If it kicks in, starters good.
Also, if you've got a voltmeter, check the battery and see if you're getting 12V. Then leave the voltmeter hooked to the battery and try to crank it, watching the voltmeter. If it drops to zero, you've got a bad battery.
I had a full 12V at the battery but every time a load was put on it, it'd drop to zero. Take the load off and it'd shoot back up to 12V. Also bought a new solenoid and it was bad. Bought a 2nd one and it was good. It happens.
