Metra Kit for in dash cd
JMcTurnan
Post by JMcTurnan »
I got a quick question, will any stereo fit in that?
towtruckerfour
Re: Metra Kit for in dash cd
Post by towtruckerfour »
It is a plastic molded piece. I just looked at mine and there really isn't any room for modifying it. The opening is 2 1/8 by 7 1/8. Hope that helps. I would think most after market decks would fit.
Troy
flyboy2610
Post by flyboy2610 »
If it's a single DIN stereo, which most aftermarket units are, it should fit just fine. The sleeve for the stereo slides into the plastic piece, then push down the appropriate tabs on the sleeve to lock it to the plastic piece.
Here's a step by step of what I did:
http://www.fordification.com/forum/view ... 64&t=42987
JMcTurnan
Post by JMcTurnan »
I was wondering how you did it, you have to cut the inner piece out. I don't have a dremel tool, but a heated knife should melt through right?
JMcTurnan
Post by JMcTurnan »
Uh oh, I have tabs on the top and bottom! Ill see if I can modify it to work, hopefully.
flyboy2610
JMcTurnan wrote:Uh oh, I have tabs on the top and bottom! Ill see if I can modify it to work, hopefully.
Top and bottom of what, the stereo sleeve? Just use a couple of the bottom ones and a couple of the top ones. You'll be set.
JMcTurnan
Post by JMcTurnan »
But isnt the tabs on the metra kit on the side? I dont know what I could screw through.
flyboy2610
Where do you have tabs on the top and bottom? I'm not following you here.
JMcTurnan
Post by JMcTurnan »
Yes, the metal tabs from my dash are on top and bottom, ill just spot weld some tabs on the side.
flyboy2610
Hmmm. I've never heard of that setup before.
You should be able to weld some metal tabs on there, though. Good luck with your project! :thup:
JMcTurnan
Post by JMcTurnan »
Thanks, yea I know. Everyone told me all 67-72s had side tabs. Its really wierd.
