StarRrRrRrRting problems.
- 70_F100
Re: StarRrRrRrRting problems.
Only if you've got a REALLY BAD oil leak!!!
Chebbies are bad for that...
- ToughOldFord
Nothing will come out when you pull it. You'll need an extension a little bit longer than the starter to get to the top bolt.
The cable between the starter relay and the starter isn't a ground, it's what feeds the hot to the starter when the ignition engages the relay. Anchor the cable to the inner fender to keep it away from the manifold.
- 72bumbee
I guess a standard extension that comes in my "junior mechanics socket wrench set" will be too short?
“To succeed in life, you need two things: ignorance and confidence.”
Mark Twain
1972 F-250 Camper Special. 360 A/T P/B AND a DANA 60 Rearend!
Former owner of dads 1967 F-100. It has gone home to the big road in the sky...
Mark Twain
- 72bumbee
Yer funny!70_F100 wrote:Only if you've got a REALLY BAD oil leak!!!
Mark Twain
Mark Twain
i use a 6 inch and a three inch extension and a regular socket. or a 6 ich extension and a deep socket. either of those combinations have worked for me.
- 70_F100
If you've got a "wobble" extension, it works WONDERFUL!!!
Be sure to use a short socket with it, to avoid interference with the starter housing.
- 72bumbee
I am still trying to figure out how that thing is going to come out? I see 2 bolts, and can feel a third. Is that right, or is there some hidden?
Mark Twain
Mark Twain
thats all the bolts there are is just those 3. plus the wire going to the stud
- ToughOldFord
That's it, just the three mounting bolts and the nut for the cable and it comes out. Careful not to drop it on your face! I darn near did once when the new starter slipped out of my hand putting it in. Man, that'd be hell on the teeth.
when i drop a starter. i disconnect the battery remove the moutning bolts let the starter down and then take the power wire off. so it can hang down and i dont have to mess with the wire while the exhaust is in the way. it canbe doen a million different ways. thats just the way i do it.
- 72bumbee
I have wiggled this starter a zillion different ways. I cannot get the darn thing to drop out! Is there something I can do to make the old one come out? Un doing the mounting bolts was a piece of cake compared to this. I have a job tomorrow, so I need to get this rolling today. I can post pics if there is anyone on who can figure this out.
Thanks Steve
Thanks Steve
Mark Twain
Mark Twain
- 70_F100
It should slide straight out of the bellhousing.
The only thing that might be catching it would be that you've got it turned in such a way that it's hanging on the flywheel, but that's doubtful.
Is it clearing the motor support and exhaust?
This may seem to be a stupid question, but you did take out the three bolts next to the bellhousing, right? 1/2" socket on a ratchet and extension, correct?
You didn't just remove the two at the end of the starter, I hope.
If you've got pics, post them. That may help us to help you.
- 72bumbee
if your going to be on for a while, I can run out and take some pics. It isn't hung up, it cannot clear the exhaust or motor mount. I come a half inch from clearing the bell housing, and even at that, I cant get it to fall through a spot.... Lemme get some pics
Mark Twain
Mark Twain
- 72bumbee
Take a look at this. Can you see where I am hitting the exhaust? Also, I have just a smidge to clear the bell housing! Looks to me I may have to drop the exhaust manifold?
Mark Twain
Mark Twain
- 72bumbee
more
Mark Twain
Mark Twain
