crazy light fix
crazy light fix
I bought a 67 f100 that none of the rear lights worked. It was getting power to all the sockets. I figured out that the bed was not grounded to the frame because of the rust on the frame. I ran a new ground from each of the rear tailight frames and now it works grreat. i justed wanted to let anyone that might have the same problem what i did to fix it. I hope it can help someone that might be scratching their head.
Re: crazy light fix
that also happens on other trucks that use wood blocks between the frame and bed.
Re: crazy light fix
I wonder if that might be part of my problem. I rewired my rear lights in my 67 F100 because only one was working and everytime I tried to fix it the other light wouldn't work then. After rewiring everything works but the turn signals give me the rapid flashing which is supposed to indicate a burned out bulb. I have triple checked all the bulbs and they are all good. All the turn signals work but only in rapid flashing mode.
Anybody have an idea what might be causing this? I think I'll add a ground between the light assembly and the frame.
Any thoughts would be appreciated.
Thanks
R
Thanks
R
- TNIceWolf
Re: crazy light fix
Could be a weak flasher retriever.
Presently in the stable
1969 Ford F-350 DRW
1969 Ford F-350 DRW
- m-mman
Re: crazy light fix
The "ground" circuit going back to the the battery has been called the 'invisible' wire.
Because you cant see it, it is easy to forget it is an essential part of any circuit.
Thanks for remembering to post your experience and add to our knowledge base.
- rjewkes
Re: crazy light fix
I think thats the frustration as i remember chevies batteries mostly ground to the frame and then the engine from the frame. and then ford goes the other way engine, then frame and also firewall.
Re: crazy light fix
tnicewolf,
I'm not familiar with the flasher, what exactly do you mean be weak flasher? Is there a flasher module/unit? Where is it located? Anyway to test it when I find it?
- 70_F100
Re: crazy light fix
Yep, sounds like a bad/weak flasher.
The flasher is the device that makes your turn signals flash. The most common types are resistance or mechanical. The one that works on resistance relies on the resistance of the bulbs to heat up a miniature coil which in turn pulls in the second leg of the wiring. It's basically a relay. The mechanical ones actually have a motor inside. The third type I'm aware of is totally electronic.
Either way, it should be a round "canister" that is about an 1-1/4" in diameter. It may be about an inch long, or it may be about 2-1/2 inches long. Or, you could have a rectangular one, about 1.5x.75x.75. Hard to say what a PO might have put in a 67 in the last 40 years.
Look under the dash, to the left of the steering column. This should be (whether round or rectangular) an aluminum case with 2 wires going to it. Some, however, have a clear plastic housing.
You can pick up a replacement at any auto parts store. Your best bet is a heavy-duty unit designed for cars/trucks that will pull a trailer. If you get one that is designed for only 4 lights (front & rear turn) and you decide to pull a trailer, the turn signals will blink extremely fast due to the added resistance of the trailer lights.
Re: crazy light fix
if you cant find the flasher can on the left of the dash. it may still be hooked to the back of the instrument cluster. you will have to reach way up in there to get at it. or remove the instrument panel to get at it.
Re: crazy light fix
There are 2 flashers, 1 for the turn signals and one for the 4-ways. If your 4-ways work it could be the turn signal flasher. Just swap them and see if there is any change.
69 F-100 Ranger 302
- 70_F100
Re: crazy light fix
Good point, QC.
Undoubtedly, though, he needs to replace it. The old resistance-type units were notorious for creating the kind of issue he has, especially on Fords.
Never saw it much on GM or Chrysler. They just stuck on and didn't flash at all when they failed.
- sideoilerfe
Re: crazy light fix
Not on my '75 Dodge Dart. When the flasher failed I had no signal at all. Nothing stayed on and nothing blinked.70_F100 wrote:...Never saw it much on GM or Chrysler. They just stuck on and didn't flash at all when they failed.
1970 F250 4x4 390/4spd
1968 F250 4X2 360/C6/No Rust!
- 70_F100
Re: crazy light fix
Good point.
They did one or the other, but the Fords flashed really fast, almost so fast you couldn't tell that it wasn't steadily on.
One point, though. You're talking mid-70's.
I'm THINKING mid-60's.
Communication failure... LOL
Re: crazy light fix
i was told that the hazards had a heavy duty flasher and if you put the headyduty flasher on your turn signal side also. that it would make the turn sigala faster even without a trailer. i cant remember if i have ever tried it but i do remember a guy named barry told me that. he was into these trucks back in the late 80's early 90's.
Re: crazy light fix
Suttonsd,
Where did you ground the rear lights from and to where? Can you give a description of what to do? I don't know where to start. If SuttonSD can answere can someone chime in? Thanks.
