Wire for radio?
JMcTurnan
Re: Wire for radio?
Post by JMcTurnan »
Maybe I don't have the expirience you do, but Im learning. And thats what matters to me.
70_F100
Re: Wire for radio?
Post by 70_F100 »
Where the h@!! is it -20 in early September?
70_F100
Re: Wire for radio?
Post by 70_F100 »
Are you in Antarctica?
Re: Wire for radio?
i understand the need or want to get the job done sometimes. as far as disconnecting the heater wire i woudlnt have if thats what you did .i went and drug out a harness to look at. the heater iwre is brown i am sorry i got that wrong. the radio runs off of its own fused wire. the factory hook up is a black wire. with an inline fuse. it plugs into the three socketed female plug on the drivers side of the instrument cluster. the gas guage cargo light and door dome light swithces may also get power from the same plug.that plug is a ignition on and off plug. it is the only 3 female plug on the main harness in that location. it is hard soemtimes to remember everything i am sorry i gave you the wrong information. if you can put back your wire with a good connection do it . clean the fuse holder and replace the fuse that should fix the heater and not give you a mess of cut wires under the dash. a messed up wiring system can give you the "f " it attitude later in your history with the truck. just run your new inline fused wire to the 3 pronged plug behind and on the drivers side of the instrument cluster. that will give you power to the radio with the switch on.
taylor351
Re: Wire for radio?
Post by taylor351 »
If you are going to "rig" wiring make sure you have a fire extinguisher handy at all times.
Keith
2004 Dodge Ram 1500 Quad cab 4.7 liter Daily Driver
1993 f150 351 4x4
1969 f100 Ranger daily driver wantabe
1972 classic c10
Proudly serving Christ since 2000
God bless our troops
A bitter rural American clinging to my guns and my religion.
JMcTurnan
Re: Wire for radio?
Post by JMcTurnan »
Its not negative 20, but it was an example. I had to do what I have too, but when my new fuse box comes in, I can do it right. Thanks fordman, mistakes happen, I will look there. If i cant find it or get it right, Ill just run an inline fuse from the accessory.
JMcTurnan
Re: Wire for radio?
Post by JMcTurnan »
Well, the heater wire wasn't running any power, and I don't know how to get a new wire, in the spot behind the fuse. Because you cant really just "work" it in there.
Re: Wire for radio?
heres a pic of that plug i was talking about its the plug right in the center ofthe picture up front of all the other wiring.
rjewkes
Re: Wire for radio?
Post by rjewkes »
man i forgot about that plug, i know my fuel gauge has been plugged in there.
and the radio is too, i need to remember it for the next time i wire up an i- switch connected accessorie.
you should see my wiring for the radio amp and cb as well as the tach. i have 2 or 3 y[ connections made with shrink tube style bullet connections running off the radio connection. and it works with everything on it isn't enough to blow the fuse. and all my accessories have their own inline fuse to.
JMcTurnan
Re: Wire for radio?
Post by JMcTurnan »
Ill look for that.
JMcTurnan
Re: Wire for radio?
Post by JMcTurnan »
I got some inline fuses, but It was just that one, its a safe wiring job down there. So Im good there. just its appearence wouldn't be considered proffessional.
flyboy2610
Re: Wire for radio?
Post by flyboy2610 »
towtruckerfour wrote: The cigarette lighter wire is constant 12v regardless of ignition.
When I install my power door locks, that's the wire I plan to tap.
rjewkes
Re: Wire for radio?
Post by rjewkes »
i have a plan for taping into switched 12v for power windows, if i get some replacement window tracks for the cougar i might just refurb the ones i have now and adapt them to the truck.
these look to have a motor driven version of our window regulator. just shortened and moved lower and to the senter of the door.
