Installing duel volt meters... update 9/7
70_F100
Re: Installing duel volt meters... update 9/7
Post by 70_F100 »
:yt:
If you can't find a nice-looking momentary-on switch, you can always use a push-button starter switch.
With a toggle switch, it's possible to leave it on and forget it, and you'll eventually drain the battery.
Thunderfoot
Re: Installing volt meters... update 9/6
Post by Thunderfoot »
kaptnkaos wrote:With the head lights off, at idle it's just above 12v, when I rev the engine, it goes to 14+/-.
When I turn the headlights on, it drops below 12v at idle, when I rev it goes to about 13vKaptnKA 8) S
Sounds like you have a problem with either the voltage regulator or alternator (would guess the alternator) as the voltage should be around 13.5V+ minimum at idle and when reved up it should not go above 14.5V. :2cents:
kaptnkaos
Post by kaptnkaos »
Hey Thunderfoot...
Yeah that's the conclusion I came to as well...
It could be the battery isolator, it is new as well.
How can I tell for sure which one of them it is?
Both were replaced less than a year ago, but only have about 300 miles on them.
I've got a 100amp alternator comin' from Robert (rjewkes).
KaptnKA 8) S
