StarRrRrRrRting problems.
70_F100
Re: StarRrRrRrRting problems.
Post by 70_F100 »
You can verify whether or not it's the crankshaft/thrust bearing by prying the crankshaft in BOTH directions.
I would personally do that right away. If the bearing is worn enough to cause the problem you're having, total failure would cause block AND crankshaft damage. If you catch it soon enough, you MIGHT get by with just replacing the bearing.
rjewkes
Post by rjewkes »
BTW That Auto China starter looks like it was a returned/returned damaged item as per that yellow sticker that was on the side of it.
72bumbee
Post by 72bumbee »
I will check that bearing. I just had some wood to get and needed it running. I was very upset with the way Auto China treated me so returned their starter for the core charge on the NAPA starter.
Have another Month lay-off coming October or Nov. I will replace the water pump, belts, upper and lower radiator hoses, and altenator. Most likely I will buy that shim plate, and fix that too I also have some wiring issues to address.
I am still thankful to JC that I didn't drive that nose cone through that bell housing!!!! That just floors me.
Even fixing the crankshaft bearing won't fix that problem. I need to go back to the tranny shop and see what they say about that bell.
Thanks again 70_F100 for your direction And ToughOldFord for the measurements. And as always fordman for the practical troubleshooting!
Steve :fr: :woohoo:
“To succeed in life, you need two things: ignorance and confidence.”
Mark Twain
1972 F-250 Camper Special. 360 A/T P/B AND a DANA 60 Rearend!
Former owner of dads 1967 F-100. It has gone home to the big road in the sky...
70_F100
Post by 70_F100 »
ToughOldFord, what's the chance you would clean up that bellhousing just a bit where the starter mounts, and get some more pics?
That bellhousing and the one in 72bumbee's truck really don't even look similar, based on what I'm seeing now. It may just be that the one in your photo has some additional oil/grime and what I'm seeing is an optical illusion.
It actually looks like your bellhousing is much deeper in that area, and I don't see the "rib" where the starter appears to be hitting in bumbee's photo.
72bumbee, two requests. First, would you take a picture of your transmission pan and post it? I want to make SURE that you've got a C6. Second, if you don't have the starter back on the truck yet, how about taking a measurement of the depth of the bellhousing in the starter area. You can place a straightedge across the opening and measure from that to the deepest part of the recess.
Chances are that someone replaced the original C6 with an FMX or something, and that's the reason for the starter hitting the housing. Just a thought!!!
ToughOldFord
Post by ToughOldFord »
Okay, I'll get another picture looking down. And I'll get a depth measurement too. As I recall it does have that lip, its just not easily viewable from the side. Something's definitely weird, with that spacer in place there's probably close to a quarter inch gap between the starter nose and the bell. 72bumbee's shouldn't come close to hitting. :hmm:
i wonder if he has a car transmission in there? i woul dthink they were the same but i dont know. i have a 3 psd bell. i do some checking on it.
torquemonger
Post by torquemonger »
no oil, no surprises. at least not when i pulled mine to hammer in a frost plug. your extension can be like a 6 inch or so. they are a 9/16th if i remember correctly, if not try a 1/2
67 mercury 100 352v8
2003 mustang gt 4.6L v8
grease,motors,and octane!!!
70_F100
Post by 70_F100 »
Hey, bumbee!!
Any progress on this?
72bumbee
Post by 72bumbee »
Sorry for the delay, working a LOT of OT before the next big layoff. Have hardly had the time to start the rig much less work on it. I will dig into it sometime in mid OCT or possibly Nov.
Thanks for your concern, I do appreciate it.
Steve :fr:
Mark Twain
ToughOldFord
I just cleaned up that bell a bit and tool some more pics. You can see the rib better in these. I put a straight edge across the starter mount and measured 2 5/8" from the edge to the top of the rib.
