my domelight won't work any suggestions
I tested the socket and its not getting electricity to it are there any simple things i should look for or check before i tear apart the truck just to get it to work
- SteveC
Re: my domelight won't work any suggestions
fuse i would say its a black wire with a blue stripe if i remember correctly if your gonna trace it.
1967 f-100 4x4
1988 ford f150 xlt lariat
1961 VW Beetle (wifes car)
1967 f-100 4x4
First thing I would do is pull on it lightly, see if its lose from something. Then I would run it down to the fuse box, i believe it says dome/bu lights on the fuse. Check the fuse, then test the wire on the fuse.
- SteveC
it can also be in the headlight switch
1967 f-100 4x4
1967 f-100 4x4
the power for the dome light comes from the fuse box throught the headlight switch and then to the door switches if so equipped.from the door switches to the dome light itself. if you do or dont have door switches then the headlight switch controls the dome light completely. with the turn of the knob of course. inside the headlight switch is a rheostat. that the knob when turned rides on. if that rheostat gets damaged it wotn let the light work with the turn of the knob. if you have door swithces the rehostat wotn matter. the dome light should still come on when the door open and the rheostat is bad. i think. i would start looking at a burned out bulb or the headlight switch as well as the fuse for the dome light. its the one in the upper left corner according to the book. i dont remember what fuse position is for what.
- 91Bear
The plastic cover over my dome light had disintegrated so I bought one of the handcrafted ones from Ranchero. When I unscrewed the socket to install the cover, the light went out and it sparked a little around the edge of the socket. I put the cover on and tightened it and it works fine. I guess this means I have a short?
i dont think its a short the housing grounds to the cab.
- 91Bear
