speaker set ups
- 03rangerxlt
speaker set ups
what have some of you guys done about speakers? I just got a free CD player, and one speaker is not gonna cut it!
-John
1968 and 2003 Ford Ranger
"Honey, how 'bout I lock you up on charges of aggrevated dumb slut with no future?"
-Det. Ray Carling "Life on Mars"
"Criminals thrive on the indulgence of society's understanding."
Re: speaker set ups
DO NOT CUT HOLES IN THE DOOR! If you feel you must cut holes in something cut holes in the door panels. Also some people have used the "pod" kind that have a bracket to mount to the bottom of the dash and hang down from there, or you could just get the "pod" kind and put velcro strips on the bottom and attach to your carpet by the seat that way.
Patrick
Patrick
Chevrolet
1969 F100 4X4 Highboy 390 3sp
1969 F100 SWB 2wd Auto 351w
1972 F100 Ranger XLT 302 Auto
http://mrsnicks.blogspot.com
Re: speaker set ups
I don't like the headliner ones as much, mainly because I have crappy speakers with weak magnets.
Re: speaker set ups
truthfully? i have one speaker it sits on the hump. the wires come down from behind the dash and factory a/c and hook to that speaker. the dash speaker no longer works.
- sport71
Re: speaker set ups
I had some 6x9's in my bump. They go in a speaker box that sets right under the front seat facing forward..for me they sounded great, but I also had an amp hooked up with them...
Those who do not learn the lessons of history, are doomed to repeat it.
Re: speaker set ups
I have a 6x9 in each door panel and two 6 inch speakers in the head liner. It sounds really good.
Troy
Re: speaker set ups
I have a 6x9 in each door. I didn't cut the doors. There is plenty of room for 6x9's by just cutting the panels. I went with the metal panels with the chrome trim a couple months ago. I did just have the metal panels. Sounds great with plenty of bass for my 46 year old ears.
I mounted the Sony CD player using the stock radio bezel years ago. I just had to clearance the opening and hang the rear of the stereo from the stud under the dash. Works great
clint
clint
71 F100 SportCustom
1986 Bronco 5.0 AOD
1986 Bronco 5.0 AOD
- fordboy69
Re: speaker set ups
I have a pair of MTX audio 6x9's in the door panels. They sound great
-1969 F100 360FE
-1970 F250 (Parts Truck)
- knightfire83
Re: speaker set ups
I got a 8" sub in each door, 6" on each kick panel where the vents were, and 2 tweets in the dash corners. Amp and cd changer are under the center console (bucket seats.)
Most people aka previous owners cut holes for 6x9's in the lower part of the door, but I rather like where fordboy69 has his.
1970 Ford F250 4x4 ~ Sold.
- fordboy69
Re: speaker set ups
6 speakers, wow that must sound awsome. Do the subs rattle the doors badly?
-1969 F100 360FE
- knightfire83
Re: speaker set ups
The only rattle is from the stainless trim around the door panels, they are missing some clips. That's an easy fix though once I start redoing my interior next year....
- td
Re: speaker set ups
move you tank out of the cab and you'll have lots of room for what ever you want, its a little work but well worth the benefit.
Re: speaker set ups
I have 6x9's in the same spot as Fordboy's has his. They sound great and I didn't cut the doors. It is all the speakers I need.
clint
clint
71 F100 SportCustom
1986 Bronco 5.0 AOD
1986 Bronco 5.0 AOD
- Joshpow
Re: speaker set ups
You can check out my pics from the site in my signature. I got 5.25 in the doors and a CD player. A little cutting, but hey, I plan to keep the ol rustbucket, so I better make it suit me. Even if I have to cut it up to do so!
Josh
72 F-100 Ranger XLT SWB
71 F-100 Custom SWB
67 F-350 Dually Dump
02 F-250 Stroke
71 F-100 Custom SWB
02 F-250 Stroke
- Sam I Am
Re: speaker set ups
My truck had speakers in the door panels as pictured above, but the windows wouldn't roll all the way down.
I took them out and set them in the floor for now.
If you plan to go that route, make sure the speakers you select for that location don't mount too deep or they will interfere with window operation.
