I've Got Gauge Problems
- Jay's67F100
So here's my situation, recently all my gauge lights except the turn signal lights have blown. I've replaced them twice and after about 3 times of use they all blow. Also my fuel gauge has been stuck at 1/4 tank, I ran out of gas the other day because of that. Luckily I was near a gas station when it happened. It says 1/4 tank whether the key is on or not. I put about 8 gallons in it and still says 1/4 tank.
I checked the ground wire coming from the harness and it looked okay. Could it be the Instr. Panel Volt Regulator? The other gauges work okay though.
- Montana71-F100
Re: I've Got Gauge Problems
I don't know about the guage lights but there's information on your gas guage at: http://www.fordification.com/tech/fuel- ... -units.htm
- Jay's67F100
Thanks! That helps for the gas gauge issue.Montana71-F100 wrote:I don't know about the guage lights but there's information on your gas guage at: http://www.fordification.com/tech/fuel- ... -units.htm
Check your alternator voltage output, if it is putting out to much voltage (over 14.5-15V) it could be blowing your lights... Not sure what else could cause them to blow unless just faulty lights.
Did you replace your lights by part number or by what fit?
maybe you got 6volt bulbs ?
- Jay's67F100
So far I've replaced the bulbs twice, with what ever Sylvania Light Bulbs they sell at Kragens. I'll check the voltage coming from the alternator, thanks!Thunderfoot wrote:Check your alternator voltage output, if it is putting out to much voltage (over 14.5-15V) it could be blowing your lights... Not sure what else could cause them to blow unless just faulty lights.
- Jay's67F100
I'll have to double check, I just went by the suggested replacement bulb from Sylvania.cep62 wrote:Did you replace your lights by part number or by what fit?
- Jay's67F100
Okay here's a wierd one for ya, so my gauge lights have been out. On Halloween nite I went for a ride in the truck, when I turned on the lights no gauge lights as usual. When I released the e brake the lights came on!!! After a bit of driving, maybe 3 minutes, they turned off again. So the next time I came to a stop I put the e brake on then off, they came back on! Only until I went from Park to Drive, they shut off again. My guess is there's a short some where? I've tried to duplicate it since with no luck.
Check the Ground wire connection for the instrument panel, it is behind the panel on the steering column brace.
