tts flasher
tts flasher
can someone tell me where the tss flasher is at i need to replace it blinks real slow what kind do i need a heavy duty one ???
Re: tts flasher
It's mounted on the back of the instrument panel, you can see it in this diagram (#2) http://www.fordification.com/tech/wirin ... tpanel.jpg.
A heavy duty flasher will blink slower then a regular one as it is made for more lights (trailer or camper) added to the load.
Double check all your lights front and rear as less lights on the circuit will cause it to blink slower...
Re: tts flasher
get tung sol flasher number 224 or maybe slyvania 352 it is for the blinkers. the hazards are a faster flasher.
