What did you do to YOUR bump today?
Re: What did you do to YOUR bump today?
disassembled the tilt column i got out of one the donor trucks in the country. Got a buddy of mine to order the bearings, retainers, etc. Slowly the pieces for my short bed are lining up.
- 67F110
Scrubbed prolly 20 years of dirt, moss and lichen off some seriously faded paint (this truck was last registered in 1980). Found a rust spot I didn't know existed at the rear corner of the cab. Managed to remove the completely corroded/frozen headlight switch without buggering up the dash paint. Plugged in a near perfect cigar lighter harvested at the U-Pull. Made plans for Sunday to pick up a bed off a '70 Ranger so she'll finally have something behind the cab.
- wt4speed#2
We need to get together and compare column notes.Still carrying that header around in my back seat. Came in friday nite and laided down and died(hence no call ). Not going bacK to OKC till monday. Might take the good looking part of my group out to scoot a boot this friday nite(god knows she deserves it). But we got the grandbaby all day saturday while the kids move, you need to come by folr a bit.fitzwell wrote:disassembled the tilt column i got out of one the donor trucks in the country. Got a buddy of mine to order the bearings, retainers, etc. Slowly the pieces for my short bed are lining up.
took the grille, & radiator off my 68, took the top panel off the grille. drilled some index holes in the hood hinge mountings, and disassembled the left door. Hope to get the interior out this week and get the inside and door jambs prepped to paint.
'40 pickup, '51 F6, '54 F100, '56 F600, '59 F100, '60 F100,
'64 Unibody, '64 F100, '66 F100, '66 Bronco, '67 Fairlane (wife's) '68 F100,
'72 F250 '72 F100, '77 F100 4X4, '83 F150 4X4, !944 2N, 1951 8N, 1952 8N, 1953 Jubilee
1960 881 Select O Speed, 1961 801, yeah I'm eat up with it.
Non-Ford: '41 Plymouth, '55 Desoto, '67 Jaguar 420, '72 Mercedes 220
'84 Subaru GL turbo coupe. I need more garage, maybe an empty Wal-Mart.
holler at me sat morning. Got an early parts run, but should be back on the westside about 10:30 or so...wt4speed#2 wrote:We need to get together and compare column notes.Still carrying that header around in my back seat. Came in friday nite and laided down and died(hence no call ). Not going bacK to OKC till monday. Might take the good looking part of my group out to scoot a boot this friday nite(god knows she deserves it). But we got the grandbaby all day saturday while the kids move, you need to come by folr a bit.fitzwell wrote:disassembled the tilt column i got out of one the donor trucks in the country. Got a buddy of mine to order the bearings, retainers, etc. Slowly the pieces for my short bed are lining up.
- Off The Jeep End
Got my new to me rear window installed
- austin
fired her up and let her idel for a bit
Full tune up. Points and ignition stuff. Checked oil pressure and am going to replace sending unit on Saturday.
It shot and humid here right now.
Russ Stanley
68 F250 ( ol' Grand Dad)
71 F100.( Old Blue)
65 Valiant Wagon (Gone but not forgotten)
2007 PowerStroke(The Golden Goose)
71 F100.( Old Blue)
installed a new hood, fenders, bed and doors.
- Wes
Fixed the brake light switch, got under the back and removed all the extra plug ins and wiring from P O. Rerouted and re-taped rear loom, fixed right tail light. Installed two halogen head lamps. Then went for a short drive.
Wes
67 F250 High boy
69 Bronco
67 F250 High boy
69 Bronco
- HillbillyDelux
did some serious wash an wax then took it up the road an did a lil burnout haha gotta love it
2000 Ford Ranger 4x4 "DD"
2003 Cobra
"If it ain't broke fix it til it is"
2003 Cobra
i spent a whole 20 minutes at the junkyard. and i got my clip for my steering shaft. i got 2 of them. yes that other brand has and uses them. that is where i found both of them. one is the original stlye and the other is a differnt style but works the same.
- rjewkes
Drove it into town for the first time in a month, all the rest have been start it and move it around the yard.
- 1967AceStroker
Took it cruising for a while, and did some... burnouts!
My Project Thread (Not updated in years.)
1967 F-100, Shortbed, 351W - 72mm Single Turbo - Megasquirt MS3x Engine Management, Tremec TKO 500, Ford 9" - Strange Nodular Center Section - Strange 35 Spline Axles - Strange Full Spool - Caltracs - DJM Drop Kit, Crown Vic IFS Swapped - 2 Coils Cut, Power Steering, Power 4 Wheel Disc Brakes, Paint - Kona Blue
Got the stupid lug nut lock off that I lost the key for. Cleaned up my back yard and put the fenders + inner fenders I had stored under the deck in the back of the truck. Home appraiser coming tomorrow. This weekend I WILL get that leaky wheel cylinder replaced.
Patrick
Patrick
Chevrolet
1969 F100 4X4 Highboy 390 3sp
1969 F100 SWB 2wd Auto 351w
1972 F100 Ranger XLT 302 Auto
http://mrsnicks.blogspot.com
