Brake lights work for a second then shut off
broncbuster500
Post by broncbuster500 »
Hello, I just bought a '71 F-250 and the brake lights did not work. I replaced the brake light switch at the pedal and they worked fine for a day, and now they just turn on when you first press the pedal and then immediately shut off. Any ideas?? Thanks!
Jed
70_F100
Re: Brake lights work for a second then shut off
Post by 70_F100 »
Sounds like you may have bought a defective switch...
Just plug a jumper wire across the two terminals in the connector and see if they stay on.
If so, go get another switch.
If not, you'll have to look further!!!
