What happened to the headlight switch thread?
- 91Bear
I saw a thread on here earlier today where Keith posted a picture of the special tool needed to remove the headlight switch nut. Where did the thread go? And where do you get one of those tools?
Re: What happened to the headlight switch thread?
http://fordification.com/forum/viewtopi ... 2&p=252388
![Image](http://www.fordification.com/board/wiper-switch-removal.jpg)
That thread contained a link to Eastwood Co. where you could buy this tool, but I see the link no longer works. I did find these links which appear to be the same thing:
http://www.mustangsplus.com/xcart/produ ... uctid=9542
http://www.wildhorses4x4.com/product/Be ... h_Switches
- 70_F100
A pair of needle-nose pliers work well...
That's not an oil leak
They might work...but they don't work "well".70_F100 wrote:A pair of needle-nose pliers work well...
![Wink ;)](./images/smilies/icon_wink.gif)
they can be used if you are careful. but i have had them slip. or mess things up before.
- 70_F100
That's what I've always used.FORDification wrote:They might work...but they don't work "well".70_F100 wrote:A pair of needle-nose pliers work well...Messing up the bezel is inevitable unless it's already very loose. If it's already messed up and you're replacing it, then yes you can use needlenose pliers. But don't use them to install a good replacement.
I've changed many of them in the last 40 years, and never messed up a single one.
The key is to have the right size needlenose pliers and to be VERRRRRRRRRRRYYYYY careful, or, like you say, you can easily mess up the nut.
Dennis Carpenter sells the proper tool also.Part number TL-200 at a mere $15.00.OUCH ! but I needed the right tool for the right job.Get you one.
1967 Ranger,Short bed,390,C-6,9 inch,4 BBL.,intake,cam,headers,3:55 Posi.,A/C,Power steering,Power Disc Brakes,Automatic trans.DJM dropped I-beams,flipped rear hangers,headlight harness upgrade.ExTang tonneau cover "Old Blue".
http://s508.photobucket.com/albums/s328/BigSxy96/
1967 Base model,352,2bbl.,3 on the tree,short bed,3:25 9 inch "Rusty".
1967 Mustang coupe-show car/garage queen.Small Block,alum. heads,Nitrous,4:11Locker,Areospace brakes "Mystang".
1996 F-250 Powerstroke-Big intake,exhaust,injectors.(Nice Smoke Show) "Big Sexy"
