Good day Robert and Hazelnut, thanks for replying!
DuckRyder wrote:I tried to play the video on my desktop but it says a codec is missing, so I'm reduced to listening on the laptop.
Sorry about that. I know that the encoding I used wasn't widely supported, since it's so new. Next time I post a video I'll try to use an older, more established format.
DuckRyder wrote:I do agree it sounds like something on sheet metal, My first though was something perhaps hitting the alternator fan. Could also be the inspection cover. You can run it without the inspection cover for testing purposes.
This I will do!
The alternator fan looks OK and I couldn't hear anything unusual through my iron pipe (physically touching the alternator case and my ear).
This said, I did make a somewhat unpleasant discovery. When I put the pipe to my ear and touched the OIL PAN, the tapping sound came through loud and clear! Now I'm imagining the crankshaft hitting the windage tray in there or something.
DuckRyder wrote:It sort of sounds like two noises to me, in addition to the sheet metal noise it sounds like it has some valve train noise as well.
Okay! Welp I'll try to figure out them one at a time. Hopefully one of those sounds is just an artifact of my video camera's poor microphone, but we shall see!
DuckRyder wrote:I wouldn't worry much about anything in the exhaust past the head to header joint at least not now.
Yeah I see your point!
hazelnut wrote:I havent seen the video but you might want to pull the coil wire(motor cant start) and the inspection cover and have someone bump your motor over while your under the truck and see if you see any fresh looking rubs anywhere inside the inspection area and have a look around with a flashlight.Sorry left out the most important part,block your wheels so the truck cant roll.
Hey Hazelnut, that's a great idea. I may try that later today when I have a helper on duty!
Since I heard the sound pretty clearly from the oil pan area, it seems like I may need to rip that apart again.
But since that's a huge job, I'll take the clutch inspection cover off first and look around in there as well as I can.
If that sound truly is coming from the inside of the oil pan, what potential causes come to mind?
Thanks very much for the expert advice!
Robroy
